20 Most Recent
TalonSoft East Front 2 for Windows Questions & Answers
East West Fron or Operational Art of War able to
I got talonsoft eastfront II to run on my windows 7 laptop by using two pieces of software. First I use vmware player and created a virtual machine with a winxp install. Second, I ripped the original game CD using alcohol. This creates an image that preserves the special formatting that is necessary because of the SafeDisc copy protection that is used in this talonsoft game. I mount this image using alcohol since my laptop does not have an optical drive. The vmware player sees the mounted image as a normal cd drive with the original game cd in it. I can install and play eastfront II in the win xp virtual machine. I installed the 1.02 patch. No other special settings were necessary. All features appear to work with this setup. The videos play, the unit viewer works (help files with transparency does not work in win 7 normally), background music and sfx are streamed off the virtual cd.
I'm running Windows XP. The
right click the program icon, click properties, click compatibility tab, click on run compatible with and choose windows xp sp2, then ok.
Talonsoft east front will not load on windows
make sure the game is compatible with vista and if it is older game made in 1995.then you might have to
explore the cd and right click and properties.find the tab that says compatibility and click what ever year it was made in
if you got all of the back up cd to your vista machine. you can put two operating systems on it and put xp
on at the same time with vista.if you got a xp installation disk i can email directions on how to get two operating systems
please email with any questions at
[email protected]
Old alchemy game will not install
Try this:
Right click on the D:/Poppack-setup.exe -> Properties = Compatability Tab.
There should be a box that says "Compatibility Mode" that you need to chek, and then select Win95 and hit OK.
Try installing again.
If it still gives the same error, go back to the tab and go lower than the Compatibility Mode box, to Display settings, and chek "Run in 256 colors" and "Disable Visual Themes"
Try again.
If it still wont work, please respond. If it gives a different error at any time or a different problem, please respond.
If it works, please rate. :)
Cant play on current windows nt
Right click on the game you want to play and click "properties". Click on the "compatability" tab and choose an earlier operating system. Try each till you find one best for your computer.
