20 Most Recent
Cosmi Swift Classics: Card Games for Windows Questions & Answers
Just installed Windows7 x64 bit on a new pc.
Lower bit-rate should not be a restriction on use.
For programs one can use the compatibility mode, both the installers and executable files. Click right for the context menu and don't go to Compatibity but Advanced. Choose the Tab Compatibility and select the Windows version that seems to be fit from the list.
The program can not be rewritten. For DOS there are programs like DosBox where you can drag old DOS programs onto. Windows can be installed in separate partitions, the older versions first. Then accessed by Windows boot menu. Another idea is to make a virtual disk and install the old Windows version from there.
I am looking for Swift
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
I have Cosmi Card games
Right click on the icon ,select properties -->compatiblity tab -->check run this program in compatibilty mode.-->click apply ok.
I cant load this Cd
I cannot my Swift Classic Card Games for Windows. My operating system is Vista. Is that the reason?
