20 Most Recent
Atari Act of War: High Treason for Windows Questions & Answers
How do i get Act of War high Treason to work on
THIS IS THE FIX for Act of War and High-Treason
look no further, here is the solution for the memory and video memory crash. You need to go to your game location:
1- For steam users its Program Files (x86) >> Steam >>
steamapps >> common >> Act of War High treason (else its the
normal
Program Files (x86) >> Atari >> Act of War High treason and right click on ActofWar_HighTreason.exe and put the compatibility mode on one of the Vista.
2- Downloadhttp://cns-spb.ru/d3d9.zipand put that .dll file in same location.
Remmember to store this file for later use, since we dont know how long the link will be up and spread the massage since there are many who has trubble running this game.
Works at least on W7 Ultimate x64 sp1
High treason download won't work
First uninstall and reinstall the whole game. Then make sure you have
the latest patch. If that does not help here are good instructions
for installing AND running the game as
administrator and with compatibility mode (if you are running Vista or
Win7:
http://www.ataricommunity.com/forums/showthread.php?t=659761
This also has helped to solve a lot of issues:
http://www.ataricommunity.com/forums/showthread.php?t=455721
Just installed act of war high treason. Wont let
Here are good instructions for installing AND running the game as administrator and with compatibility mode (if you are running Vista or Win7:
Retro Gamestick need help?
To emulate Amiga buttons on your X2 Plus Game Stick Retro Console, you can use an emulator like Amiberry or lr-puae . Here are the steps to emulate Amiga buttons on your X2 Plus Game Stick Retro Console using Amiberry:
Install Amiberry on your X2 Plus Game Stick Retro Console by following the official installation guide .
Download the WHDLoad packages for Amiga games you want to play .
Place the WHDLoad packages in /home/pi/RetroPie/roms/amiga/.
Configure your controller by following the official controller configuration guide .
Launch Amiberry and select the game you want to play .
If you prefer to use lr-puae, you can install it from the optional section of the RetroPie-Setup Script . Once installed, you can place your desired Kickstart ROMs in /home/pi/RetroPie/BIOS/ and use disk and WHDLoad games with this core .
Amiga - RetroPie Docs
TikTok - Make Your Day
Amiga Gotek: Getting started guide ' Installation ' Set up and Game downloads (FlashFloppy) - Retro32
Atari flashback 9 gold wont start get error message
I'm using the same SD card I did with the portable. I didn't have to change the file names for the games. The console recognized them. The save slots also work with the roms in the SD card, which is really neat.see: https:https://sarkariresult.onl/ , https://pnrstatus.vip/ & https://19216811.cam/
