20 Most Recent GE Swingline 690E Electric CartridStapler - Staples & Stapler Supplies Questions & Answers
Stapler won't stops stapling
poor connection internally
4/3/2013 11:07:55 AM • GE Swingline... • Answered on Apr 03, 2013
GE dehumidifier ADHL35 all display lights flashing and alarm sounding. What's the problem?
If all the display lights on your GE dehumidifier ADHL35 are flashing, and the alarm is sounding, it indicates that the dehumidifier has detected a fault or an issue that needs attention. The specific problem could vary, but here are some common reasons for such an error:
  1. Full Water Tank: The most common reason for alarms and flashing lights in dehumidifiers is a full water tank. Check the water collection bucket or reservoir to see if it is full. If it is, empty it and make sure it is correctly repositioned in the dehumidifier.
  2. **Air Filter: **Some dehumidifiers have a filter that needs regular cleaning or replacement. A clogged or dirty filter can trigger an alarm and flashing lights. Check the user manual for instructions on how to clean or replace the filter.
  3. Temperature and Humidity Levels: Extreme temperatures or high humidity levels can affect the dehumidifier's performance. Ensure the dehumidifier is operating within its specified temperature and humidity range.
  4. Obstruction in Airflow: Make sure there are no obstructions blocking the air intake or discharge vents of the dehumidifier. Blocked airflow can affect its operation and trigger an alarm.
  5. Internal Malfunction: If none of the above issues are the cause, there might be an internal malfunction in the dehumidifier's electronics or sensors. This could require professional diagnosis and repair.
Here are some steps you can take to troubleshoot the issue:
  1. Turn off the dehumidifier, unplug it from the power source, and wait for a few minutes before plugging it back in. This can help reset the electronics.
  2. Check the water tank and empty it if it's full. Ensure it is correctly positioned and seated in the dehumidifier.
  3. Clean or replace the air filter if necessary.
  4. Ensure there are no obstructions blocking the air vents.
If the problem persists after attempting these troubleshooting steps, it's best to contact GE customer support or a qualified appliance repair technician. They will have the expertise to diagnose and fix the issue properly. Avoid using the dehumidifier if it continues to display an error or alarm, as using it in a faulty state may cause further damage or pose safety risks.
7/26/2023 5:24:54 PM • GE Office... • Answered on Jul 26, 2023
I have a GE GFDR270EH dryer. I ran diagnostic and received error code 009. Does this mean the switch is bad, the motor is bad, or the relay is bad?
Hi, If you hit the start button on your dryer and you hear a loud buzz or hum, then that would mean that your motor is bad. You might schedule an appointment with a Home Depot repair specialist to have the dryer further analyzed. Their number is 1-800-HOME-DEPOT (466-3337) Thank you.
10/12/2022 7:18:26 PM • GE Office... • Answered on Oct 12, 2022
I have a GE JE1540 microwave no longer made. I need a new microwave with the same measurements (see below) that is installed above the oven. What would be the new model number for replacement?
GE JT955, GE JT952, GE JTP48 and GE JTP28 are few models to help you with the dimensions of the Microwave Oven as per the requirement.
5/12/2019 2:52:52 AM • GE Office... • Answered on May 12, 2019
0answers
Consumer studies ge 10 past year papers
This does not belong on this site.
9/3/2017 2:10:24 PM • GE Office... • Answered on Sep 03, 2017
0answers
2answers
Turned on inserted new ink cartridge typed letter went to print printer no longer showed it was working cant ge it to turn back on using in windows 10 can you tell me what is wrong with the printer
If you need Lexmark Printer Tech support phone number, then you can contact with us, Lexmark Printer Customer Service Phone Number 1877-778-8@9@[email protected] are always here with tech team for your help. For further Info Click On Me: https://goo.gl/hvj3MK slide1-ylkng2ipf1liuwgzt4hyff3a-3-0_0.jpg
3/28/2017 11:22:44 AM • GE Office... • Answered on Mar 28, 2017
Washer overfilling
check for the water level controller is switching of the water control solenoids check that the solenoid solenoids are working and not just humming if they are humming , replace the control unit
6/23/2016 10:52:36 PM • GE Office... • Answered on Jun 23, 2016
Need install manual for the GE 98614 Wireless Key
if u need just the manual whit install help u can get it from the manufacture website, here is the direct link for your product (its a pdf file so u will need adobe reader to open it): http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/98614-Manual-Eng.pdf
i hope will help you, if u need drivers or something give the product code so i will check on GE website.
best regards
9/20/2011 4:24:32 AM • GE Office... • Answered on Sep 20, 2011
4answers
How many ounces of body lotion is 200 ML ?
200 ml is about 6.76 US ounces or about 7.04 UK ounces.
4/24/2024 8:53:54 PM • Office Equipment... • Answered 4 hours ago
How do these points equate to money?
No money ever! There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun. ADMIN Andrew
  • Answers: 65,820 and not a penny per Answer.
Head over to www.justanswer.com they pay lots of money because they charge for people to ask a question. ..
4/19/2024 9:45:02 PM • Office Equipment... • Answered on Apr 19, 2024
GE Swingline 690E Electric CartridStapler - Staples & Stapler Supplies Logo
2 questions posted
Top GE Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Sudarshan Shyam
Level 1 Expert
Are you a GE Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • GE Office Equipment & Supplies
Most Popular Question
stapler won 39 t stops stapling
  • Office Equipment & Supplies
