20 Most Recent
EA - Electronic Arts Rock Band Questions & Answers
My ps2 wont read the disk. says there is no data. help
it's your laser with something like dust keeping it from reading the discs. Just get a simple CD cleaner kit, one that has the little brush on it and then of course put some solution on it. Rubbing alchol will due. This happens to everyone eventually.
Should do the trick.
If it doesn't do it after playing the cleaning disk three times for around 10 secs each, then you may want to open it up and put clean the laser lens directly with a rubbing alchol soaked que tip and a dry one. For more instructions on how to open it do a search on fixya and there is one guru who goes into great detail about this.
To play Rock Band without vocals?
Seriously you guys are hilarious, nobody's even given this guy a true and or correct answer. I too have had this problem and it's INFURIATING. Just trying to play the damn game: No you don't have to download anything
Solution:
Enter Game mode/ Training mode whatever mode USING THAT INSTRUMENT. I repeat DO not use the controller (the xbox360 controller) unless you want to use the microphone. It makes sense the microphone has no control hence by default if your'e using the controller the game THINKS you want to play with the microphone.
ROCK ON!!
Set up rock band guitar controller
Ok time to call you all idiots and ask the most basic question, did you buy this used? If so did you get the wireless receiver dongle with it? All GH or rock band guitars require a USB receiver dongle.
My ps3 system wont register
I had a mic that wouldn't register in the ps3 for Rock Band. Tried a different mic and that worked better. Possibly a short in the wires causing it not to read.
Is there a guitar hero foot pedal wire replacement
you will have to get a new foot pedal
var fctb_tool=null;
function FCTB_Init_62176759b3424b9cbe761805261ece8a(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_62176759b3424b9cbe761805261ece8a(document['FCTB_Init_4530bd1f4dd44a9eb15294e262e76316']); delete document['FCTB_Init_4530bd1f4dd44a9eb15294e262e76316']
var fctb_tool=null;
function FCTB_Init_2d8b2df2973d4407bec8a4def7152a67(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_2d8b2df2973d4407bec8a4def7152a67(document['FCTB_Init_f65b37e3b16a4105b681111044638705']); delete document['FCTB_Init_f65b37e3b16a4105b681111044638705']
Rock Band & GH guitar- is it possible?
Heres The Problem Scott.. When rock band was first released it was not compatible with guitar hero's guitar. only guitars from world tour forward will work with rock band
Whamy bar broke
It Can be repaired.. and i found some extra parts for it online. try ebay or amazon.
Help!!!
hi
i think that your playstation has worn out and i personally would be going onto a site like ebay and buying a new ps2, you could pick up a cheap second hand one for 50 bucks
Rock Band Drum doesnt work
This is a fualty reciepter inside the drum. I have not got this game so i dont know how to open the drum head or underside. however i have expierienced problems like this before. Either something has come loose i.e receptor or a wire. Or the receptor i broken which will mena buying a new one . I suggest pening it up and very carefully without electrcuting yourself touch the receptor and see if it make the drum work.
I need a fifa 12 operating
manual
Check here to
the complete
FIFA 12 In Game ManualHope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.Thank you for using Fixya, and have a nice day
