20 Most Recent Earthwise 1850 PSI Electric Pressure Washer Questions & Answers
The connection is made at the bottom of unit.
should be standard garden hose.
sometimes I find if I gently hold hose against connection point then rotate counterclockwise until I feel a click! then ( without lifting hose) rotate clockwise and hose should now be threaded onto power washer.
Earthwise 1850... | Answered on Oct 09, 2016
http://www.amazon.com/Powerwasher-80012-Universal-Electric-
This universal gun and hose may work. It comes with adapters for use with original wands. If you need the wands also, do a search for the complete kit.
Earthwise 1850... | Answered on Apr 20, 2015
It should have a tube on it put it in your bleach bottle and use the black tip for dispense 1/2 bleach/1/2 water
Earthwise 1850... | Answered on Aug 09, 2013
https://www.youtube.com/watch?v=GXZisHxEq64
Garden | Answered Yesterday
The reverse belt goes on inside out. Wide side facing the upper tension pulley. Facing the engine from the handles, over the upper tension pulley then to the right side of engine pulley narrower side of belt in toward the engine pulley, then around the bottom transmission pulley (wide side in toward the pulley. Had the same issue.
Earthwise 1850 PSI Electric Pressure Washer Logo
12 questions posted
Top Earthwise Garden Experts
Steve Sweetleaf
Steve Sweetleaf
 Larry
Larry
montehammons
Are you an Earthwise Garden Expert? Answer questions, earn points and help others
View Most Popular
Earthwise Garden
  • Earthwise Garden
Most Popular Question
hose connect washer
  • Garden
