20 Most Recent Pentair Letro Jet Vac Pool Cleaner Tire Pack of 2 - JV21 Questions & Answers
Check wall adaptor, there is a filter/screen inside.
Probably plugged with debris!
Pentair Letro... | Answered on Apr 05, 2015
if filters then no backwash needed keep filters clean make sure to clean filters with TSP first tri sodium phosphate its a degreaser then filters will be ok
Pentair Garden | Answered on Apr 07, 2018
common white, high black to #2 low red to #3 green ground
Pentair Garden | Answered on Feb 11, 2018
I believe the pot is screwed into the pump body/volute. Lift the complete pump enough to turn the entire pot counter clockwise, to unthread it off of the volute.
Pentair Garden | Answered on May 27, 2014
I really would need a picture to be more accurate. If you have no way to hold the lid on to get suction, you have to replace the front bowl (pot) as that is where the strainer basket is and how the flow is created. That bowl (pot) unscrews from the front housing. You have to be able to free the suction pipe from the bowl and have enough room to spin the bowl off. You may also have to remove the pressure side pipe if you do not have enough room to turn the bowl (pot) off. If you can not get the bowl off of the front plate, you will have to replace the bowl and front plate all at once.
Pentair Garden | Answered on May 18, 2014
If you can put some food coloring in it so you can see the leak better and you find a crack in internal or external on both fitting; may be find the parts are warn down some and may need some plumming tape put on them or replaced.
Pentair Garden | Answered on Oct 26, 2013
If it is only a pinhole it should be an easy fix. First dry the unit thoroughly, the drier the better. Then use superglue gel to patch the hole from both sides.You may wish to smooth the glue for aesthetics just make sure you leave enough so the glue can hold to the interior under pressure. The gel will dry overnight and is non-toxic. Larger holes or cracks would require a plastic welder or applying fiber glass.
Pentair Garden | Answered on Apr 17, 2011
There are several common different types of quick release couplings in the power washer world and while it is possible you have the wrong lance and hose supplied with your washer, it is unlikely.
Many quick release couplings don't just connect by pushing but have a sleeve that must be pushed forward, pulled back or twisted or a button to be pressed. Mostly diy level washers have the lance, hose and connector as an assembly and the connector can't be replaced.
Most towns contain many businesses that use heavy duty pressure washers, vacuum cleaners, parts washers and suchlike and inevitably other businesses spring up to cater for the needs of local business providing a wide range of repairs, spare parts and accessories and they of necessity gather a wide knowledge of domestic equipment.
If you have trouble or doubts I suggest you locate such a business near you...
Garden | Answered 12 hours ago
This is Stihl's manual showing the proper adjustment for the oiler. Flip the saw on its side, chain and bar side up, and look for a flat head screw.
Clockwise rotation on any saw is more oil, and counterclockwise will be less oil.
Garden | Answered 23 hours ago
ASK GOOGLE AND INCLUDE MAKE OF WHAT YOU HAVE
Garden | Answered on Aug 07, 2020
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Garden | Answered on Aug 04, 2020
Pentair Letro Jet Vac Pool Cleaner Tire Pack of 2 - JV21 Logo
2 questions posted
Top Pentair Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Pentair Garden Expert? Answer questions, earn points and help others
View Most Popular
Pentair Garden
  • Pentair Garden
Most Popular Question
jet vac doesnt move despite pump working
  • Garden
