20 Most Recent
JBL Duet Speakers, White Computer Speakers Questions & Answers
I have a pair of JBL Duet speakers and 1 doesn't
mcdevito75 here, Try to increase the volume from your keyboard, Then adjust the volume at the speakers, there should be only 1 volume control on 1 speaker to control them both, also check your connections at both speakers.
4/20/2012 7:38:03 PM •
JBL Duet...
Answered
on Apr 20, 2012
Speakers not working
If you have another computer or a friend, test them on his/her computer. Try this, as its fixed such a problem for me in the past.
Start>All Programs>Accessories>Entertainment>Volume Control
Then check the ticked/unticked boxes
11/1/2007 8:40:38 PM •
JBL Duet...
Answered
on Nov 01, 2007
How to open jbl on stage 200id?
To open the JBL On Stage 200iD, you need to follow these steps:
Remove the power adapter from the back of the device.
Turn the device over so that the bottom is facing up.
Locate the six rubber pads on the bottom of the device and remove them using a plastic opening tool.
Remove the six 1cm T-10 torx screws found under the rubber pads using a T-10 Torx screwdriver.
Open the device along its seam.
For more information, please refer to the JBL ON STAGE 200ID USER MANUAL.
https://www.manualslib.com/manual/788652/Jbl-On-Stage-200id.html
10/27/2023 9:59:32 PM •
JBL Audio...
Answered
on Oct 27, 2023
Problem with your JBL BoomBox2 speaker (or similiar) ?
Just found this out, after crazy searching & brainstorming.
So if your speaker suddenly goes silent or sound comes and goes, you can check this out:
At least the JBL BoomBox seems to have this integrated in its architecture so there's nothing we can do about it, complain to JBL : )
But to the problem: if the SOURCE of music/sound is too low, then the speaker may go into a "sleep mode" - silent. So ensure always your SOURCE of sound, connected to the speaker, has volume at least 80% to avoid this problem.
Hope this helps & no one needs to ditch and buy a new one ! : )
How do I fix a BLINKING light on the jbl 10..G2 input signal board that causes no signal to go thru
A blinking light on the JBL 10" G2 input signal board can indicate a problem with the input signal. Here are some steps you can take to try to resolve the issue:
- Check the input cables: Make sure the cables are securely connected and there's no damage to the cables or the input jacks. Try swapping out the cables with a known working set to see if that resolves the issue.
- Check the source: Make sure the source device (such as a mixer or computer) is working properly and is sending an output signal.
- Check the input settings: Make sure the input settings on the JBL 10" G2 are correct. Refer to the manual for information on the correct input settings.
- Power cycle the device: Turn off the JBL 10" G2 and unplug it from the power source. Wait a few minutes and then plug it back in and turn it on.
- Check for firmware updates: Make sure you have the latest firmware installed on the JBL 10" G2. Refer to the manual or the JBL website for information on firmware updates.
- Contact JBL customer support: If you're unable to resolve the issue with the above steps, contact JBL customer support for further assistance.
If the issue persists, it's possible that the input signal board on the JBL 10" G2 may need to be repaired or replaced. In this case, you may want to consider contacting JBL customer support for information on repair options.
2/1/2023 5:46:55 PM •
JBL Audio...
Answered
on Feb 01, 2023
My JBL e45bt wireless headphones won't turn on. I've tried charging them overnight, but i doesn't help at all. How do I get this fixed?
If your JBL E45BT wireless headphones will not turn on, there could be a problem with the battery or the charging system. Here are a few things you can try to fix the problem:
- Make sure that the headphones are charged. If the battery is completely drained, the headphones will not turn on. Try charging the headphones for at least 2 hours to see if this resolves the issue.
- Check the charging cable and port to make sure they are working properly. Make sure the cable is securely plugged into the headphones and the power source, and that the port is free of debris.
- Try a different charging cable or power source to see if the problem is with the cable or the power source.
- If the problem persists after trying these steps, it is possible that there is a problem with the battery or the charging system. In this case, you may need to have the headphones inspected by a technician to determine the cause of the issue.
If you are not comfortable troubleshooting the problem yourself, it is recommended that you contact JBL customer service for assistance. They may be able to provide further guidance or offer repair options.
1/8/2023 3:45:21 AM •
JBL Audio...
Answered
on Jan 08, 2023
