20 Most Recent Stanley CH5 - 4" 15-HP 420cc Professional Chipper Shredder With Questions & Answers
check choke for proper operation. then let us know what brand of engine is on this unit
Stanley CH5 - 4"... | Answered on Oct 20, 2013
Hi leo soriano
I know you said the machine is new, but things happen...
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible or maybe the high/ low speed jet is out of adjustment.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Stanley CH5 - 4"... | Answered on Oct 05, 2012
Chapin makes sprayers. They have parts. Just give model #. Phone 1-800-950-4458. Located in N Y STATE. Pump rebuild kit is $25.00 Inc shipping.
Stanley Garden | Answered on Nov 23, 2020
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Stanley Garden | Answered on Jun 14, 2019
Is tranny and various speeds working properly? How about the throttle control? Do you have it set for higher speed?
Stanley Garden | Answered on Aug 25, 2017
Try tilting the machine backwards for a few hours. It may be oil on the piston that is causing a vaccum
Stanley Garden | Answered on May 05, 2017
The valve-o-rings + [ parbaks seals ] where the pressure can be adjusted with.
Control the water inlet filter or hose that there are no waterlock couplers are used or is mounted
on the wrong site on the hose , that it is used as water inlet on the tap.
Stanley Garden | Answered on Dec 25, 2016
This is a terrible tool took it apart to get the blade out of the handle and haven't been able to get it back together again.
Stanley Garden | Answered on Jul 24, 2016
Try manufacturer web site.
Stanley Garden | Answered on Jun 12, 2016
Stanley CH5 - 4" 15-HP 420cc Professional Chipper Shredder With Logo
3 questions posted
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
View Most Popular
Stanley Garden
  • Stanley Garden
Most Popular Question
stanley ch5 wood chipper engine
  • Garden
