20 Most Recent
Apple iPod Photo-60GB Power Hot Sync and Charge Compact Kit w/ Tip Exchange - Gomadic Brand (BCK0010AD) Questions & Answers
How do i unlock my ipod
to unlock the ipod you just need to remember the password combination you set. Which is a series of button combinations on the ipod.
to unlock follow these steps.
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the
IPod, which will erase all music and data."
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
I was given a 60GB Ipod serial # 4J54723STXL. I
For how to use your ipod, you can download the ipod Feature/guide manual here: http://manuals.info.apple.com/en_US/iPod_Features_Guide.pdf
To put music on your ipod you'll need to download and install iTunes, which you can download here: http://www.apple.com/itunes/download/
c@rl
Forgot password on my ipod and its lock
Hard resets for all ipods are listed on the Apple Website. Just ask in the discussion area for your model.
Ususally it is a combination of pushing the touch wheel in 2 different places at once for a given amount of time.
If it can't be reset, take it to the Apple Store, they can reset anything. Remember that will wipe off your songs which you should have all on iTunes on your computer. Then just take the iPod back home are resync all your songs.
Not working properly.
Try toggling the hold back and foward and putting it back in the off position. Then hold the menu and the center button down simultaneously for about six seconds until the apple logo appears. Then release the buttons and it should work.
Pairing Apple Air Bud Clones
If they are the Apple ear bud clones, there is a technique to get them paired and
both working. You get the left to work, or you get the right to work!!
- Tell your phone to Bluetooth Search.
- Press the On button for one earbud.
- Press the On button on the other earbud and then double press the button on that one.
- Go to the phone. At the bottom of the Bluetooth list you will see two numerical entries that say paired. Ignore those. In the top list of Bluetooth items you have used before, you will see one that is the Friendly Name for your earbuds (mine says i12-TWS). Press that once and it will change to connected. Then both will be connected.
It took me weeks to find this out.
Capacity to download audiobooks
Hi there PatAccording to the user manual for the ipod nano 5th generation you can add audiobooks. These directions are directly from the manualIn itunes, select ipod nano in the devices list and click on the music tabThen select Sync Music, and then do one of the following:(a) Select "Entire music library"(b) Select "Selected playlists, artists, and genres," and then select Audiobooks (below Playlists).Click Apply.The update begins automatically.Hope this helps.
What are MOV files for?
MOV is a common multimedia format often used for saving movies and other video
files; uses a proprietary compression algorithm developed by Apple
Computer; compatible with both Macintosh and Windows platforms.To play a MOV file, use this playerhttp://movplayer.net/
