20 Most Recent Broderbund The Print Shop Pro Publisher 15 for PC Questions & Answers
Why can't I save to a PDF with Windows 7?
The Broderbund PDF converter is a piece of software that is apparently bundled with Broderbund's Print Shop. If you upgraded your OS, you may need to update your Print Shop software. If you did a "clean install" or had your XP operating system saved to an Old Windows directory, it is likely that you will have to reinstall Print Shop in its entirety. In case it helps, here is an article on someone with a similar issue: Amyuni Technologies
6/29/2015 8:13:22 AM • Broderbund The... • Answered on Jun 29, 2015
0answers
I have printshop 15 which
You can use the Revo Uninstaller to completely uninstall the application.
Click here to download Revo Uninstaller
2/2/2011 10:02:58 AM • Broderbund The... • Answered on Feb 02, 2011
Want to uninstall/remove broderbund label and
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Click to select the software
Click Uninstall
10/19/2010 9:36:19 PM • Broderbund The... • Answered on Oct 19, 2010
My Printshop 15 does not operate properly, and i am
Not sure what your exact message is but on their support site it listed this:
Invalid Page Fault in Module ADBOOK.EXE Description Solution While trying to print or preview in the Ultimate Mail Manager Address Book (included with The Print Shop® 15), the message "ADBOOK caused an invalid page fault in module ADBOOK.EXE" appears. This error is usually the result of an outdated or incompatible printer driver. Checking for proper settings or updating the printer driver or both can help to resolve the issue. The remainder of this technical note describes how to proceed. Follow the procedure below to help resolve the issue.
  1. Close all programs and return to the desktop.
  2. Click Start, choose Settings and select Printers.
  3. Right-click the icon that represents the printer being used and verify that Set as Default is checked.
  4. Choose Properties from the menu that appears. The printer Properties window will open.
  5. Click the Details tab.
  6. Click the Spool Settings button.
  7. Change the Spool Data Format to RAW.
  8. Click Apply and click OK.
  9. Close the Printers window.
  10. Open The Print Shop® 15 and Ultimate Mail Manager and try to print again.
NOTE: If the issue continues, contact the printer manufacturer and request an updated printer driver and directions regarding the installation of the updated printer driver. Typically, an updated driver can be obtained from the manufacturer's Web site.
If the error reappears after downloading and installing the new printer driver, continue with the following procedure.
Install an Emulation Driver
  1. Install a suitable emulation driver. For help identifying and installing a suitable emulation, contact the printer manufacturer.
  2. After the emulation driver has been installed, launch and use the program. The issue should be resolved.
NOTE: For some printer models, it may be necessary to switch back to the original printer driver when using a desired application in order to gain full functionality of the printer.
12/6/2009 3:42:07 AM • Broderbund The... • Answered on Dec 06, 2009
I want to remove the print-shop propublisher
Try to use revo uninstaller from here :
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Use the default settings and then delete everything it suggest.
Hope that helps
Have a nice day
Please rate my answer.
10/7/2009 2:28:42 PM • Broderbund The... • Answered on Oct 07, 2009
Cannot remove software from pc
try Tune-up utilities 2009, its got uninstall tools in it, or if you have not installed any other programs after that day you installed Broderbund print shop, open System restore and click on the date you installed it. This will uninstall the program
6/17/2009 3:11:11 PM • Broderbund The... • Answered on Jun 17, 2009
Remove software from my computer
IF UR THE ADMIN OF THE COMPUTER , GO TO CTRL PANEL AND CLICK, THE ADD/REMOVE PROGRAM AND DENOTE THE SOFTWARE WHICH U WANT TO REMOVE AND PRESS REMOVE....
OR
EVEN AFTER THAT THE PROGRAM DOESN'T SOLVED. SOME VIRUES MAY BE THEIR IN THAT TRIAL VERSION TRY TO REMOVE IT OR DELETE THE VIRUES AND REMOVE BY PROPER WAY....
12/10/2008 12:35:08 PM • Broderbund The... • Answered on Dec 10, 2008
Says Printmaster is running in another program and to close but don't know how?
Question edited for clarity. Question moved to Broderbund Graphics Press CTRL+ALT+DELETE Choose Task Manager That will show all instances of the program being open. You can End Task on ones that look like they shouldn't be open. Put the EXACT message in here https://www.google.com/search?q=Printmaster+18.1+is+running+in+another+program+and+to+close ..
1/27/2023 8:33:09 PM • Broderbund... • Answered on Jan 27, 2023
I have Print Shop 3.0 and it's been updated to 3.05 running on windows 7 and when I try to import a picture or try to save a project the program closes.I've contacted Encore and they sent me n
Did print shop 3 work properly in win 7? If so you should never have updated. See all the grief it has caused you? Go back and install the 3.0 version and leave well enough alone Or maybe that program is not compatible at all with your OS.I have mo bo's that will not load XP but will work fine with anything prior to that. Computers are unpredictable and down right ornery at times but we need them so have to play by their rules.
9/13/2017 1:27:29 AM • Broderbund... • Answered on Sep 13, 2017
0answers
0answers
Broderbund site
Be the first to answer 11/5/2016 2:13:02 PM • Broderbund... • Posted on Nov 05, 2016Be the first to answer
*.sig to PDF convert
Anyone has experience about the pdf to image conversion toolkit I am tetsing these days? Any suggestion will be appreciated. Thanks in advance. Convert PDF to Image Types in NET pqScan com
12/10/2015 2:31:40 PM • Broderbund... • Answered on Dec 10, 2015
Which printmaster program works with win 8.1
The newest version (v6 Platinum) says that it works with Windows 8. Doesn't say anything about 8.1, but it should be the same. PrintMaster v6 Platinum Broderbund Official Software Site
8/25/2014 3:43:35 PM • Broderbund... • Answered on Aug 25, 2014
2answers
I have windows vista and
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } People who use Sony and Cannon camcorders may feel frustrated trying to upload their videos to youtube, as thesy are taken and saved as mts/m2ts. Well, in fact, all they have to do is to find an mts to flv converter. How to convert m2ts to flv?
Download and install mts to flv converter on your PC. It takes only a few steps to convert m2ts to flv on Windows.
Step 1: Connect your HD video camera/camcorders to your PC. Copy the videos you want to share to your PC's hard-drive before converting or editing them.
Step 2: Launch the m2ts/m2ts to flv converter. Click "Add files" to browse your computer hard disc and add the .mts or .m2ts files you want to convert. You can load all the source files before the m2ts to flv conversion as batch converting is supported by this m2ts flv converter.
Step 3: Now you select flv as the output format and specify a directory for the output files. This m2ts to flv converter supports comprehensive video formats including avi, mpeg, wmv, mp4, mov, xvid, 3gp and more.
Step 4 (optional): The mts to flv converting program can set the brightness, the contrast and the saturation of your videos, crop, trim videos and even merge multiple files into one single file before the conversion.
Step 5: Click the "Start "button to start the mts flv conversion and all you have to do is to wait until the m2ts to flv conversion is done.
Related article: How to convert m2ts to flv and How to convert mts to flv
2/25/2014 3:46:13 AM • Broderbund... • Answered on Feb 25, 2014
Broderbund The Print Shop Pro Publisher 15 for PC Logo
23 questions posted
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Broderbund Computers & Internet
Most Popular Question
save pdf windows 7
  • Computers & Internet
