20 Most Recent
Bose SoundDock iPod Digital Music system (Black) with Monster iCarplay Wireless Plus Bundle (SOUNDDOCKICARPLAY) Docking Station Questions & Answers
My Ipod will not play music when inserted into my
If the Bose system has another kinda input that you use with another devices...and with this one you tried an 3.5 jack input...that one may be for another purpose ...So make a cable and use a normal jack for the Ipod output ...and use another input in the system ...The issue may be some kinda pre amplification needed for the entry you use..For example it mast have a 2 rca cable input like any normal system for a stereo input (or single rca) so ..either use an adapter or make a cable by adding joining an old rca on a 3.5 jack ..
If the Ipod have output signal and the system works it have to work this way ..
Or take a look into the system menu and see if you have to select the input you use ...
Remote dose not work
Get a new remote!!! I'm sure if you go on the internet you can find replacement parts and maybe a new remote:)
Missing power cable for Bose Sounddock
Repair may the only solution.
The new power supply is only slightly different though.. If you don't want to spent the $100 to repair this, you could get the new supply and carve a notch in the top part of the square power input.. Looking at the new power supply, the top is a bit taller and arched but the same specs..
But the new power supply is still expensive. (I think $60+) So for an additional $40 ($100 total) you can get a new supply retrofitted on to the old input. It's worth it- you get a new 1 year warranty, and they put the new Apple dock connector on there (USB charge pin) as well as the power supply, so you can use current iPods as well as old. (Your SD currently won't support- iPhone 3G, iPod Touch 2ng gen, or iPod Nano 4th gen.. it will after a repair)
Bose wave radio sound only works when alarm goes off
It sounds like you are experiencing an issue with your Bose Wave radio. Here are a few things you can try to troubleshoot the problem:
- Make sure the volume is turned up on both the radio and any external devices (such as a phone or MP3 player) that may be connected to the radio.
- Check to see if the radio is in "alarm" mode. If it is, try switching it to "radio" mode and see if you can hear sound.
- Make sure the radio is properly connected to a power source and that the power cord is securely plugged in.
- If you are using an external device (such as a phone or MP3 player) to play music through the radio, make sure the device is properly connected to the radio using the appropriate cable.
- If none of these troubleshooting steps resolve the issue, the problem may be with the radio itself. In this case, you may want to contact Bose customer support for further assistance.
Bose remote rcv1t-27 not working
If it's still not working, contact Bose, sometimes they will ship a replacement at no charge, if not, ship it and $20.00 to me and I will repair it or get you a replacement, if for some unseen reason it is un repairable or I am unable to get a replacement, you will get a full refund, see my feedbacks on Letgo in Fairfield California under Supertech99, 100% 5 Star feedback and reviews, I am the real deal.
What remote works with a Bose SoundLink Mini??
The Bose SoundLink Mini does not include a remote, but can be controlled wirelessly with compatible Bose Mobile and Wearable products, or with infrared accessories such as the Bose Universal Remote or the Logitech Harmony Remote.
