20 Most Recent
Sony Walkman NWZ-A828 Digital Media Player Questions & Answers
Sony walkman nwz-e344 freezes when
I had a similar problem with my Sony NWZ-818 today and simply pressed the reset button with a pin to reboot the player (little hole on the side) and it worked!
Sony Walkman connection problems
I had a similar problem, mine wouldn’t turn on unless I plugged it in the computer and then it still wouldn’t work!
I found this on Sony’s trouble shooter -
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
Battery must not be discharged 100%
If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
So I bought a USB adapter charger! Plugged it in and now it is working!
HOPE IT WORKS FOR YOU!
It wont turn on or charge what and why??
Are you trying to charge it through the computer? If so try through a main charger! I had similar problem but found this on Sony website -
Cause:
Remedy:
- Battery must not be discharged 100%
- If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
My walkman works when its plugged in but as soon
Try plugging it in to a mains charger! I had similar problem found this on sony website -
Cause:
Remedy:
Mines back to full working order!
My walkman wont turn on
Not sure if it's the same problem as mine! My battery was ran completly flat and then wouldn't turn on even after being plugged into the computer and hours of it juset sayin 'connecting'. I looked on Sony's website and found this -
Cause:
Remedy:
I bought a usb adapter charger plugged it in and its back to normal!
Bought Sony Walkman NWZ-A828 Player for my wife
Not sure if yours is the same problem but mine wouldnt turn on unless it was plugged in to the computer and even then it would respond so I search sony website and found this -
Cause:
Remedy:
So i bought a usb adapter charger plugged it in and it now is back to its former self!
Sony Walkman NWZ-A828 Connection Problems.
I have a problem with my player which could well be related, the unit appears to power off but in reality is still draining the battery (I never see the "every moment has it's music" thing)
I've replaced the battery and upgraded the firmware to no effect , so I think the hardwares at fault, all I can do for the moment is leave the player plugged into USB until I need to use it.
Sorry I can't be of more help.
NWZ-A828 connections problems in PC
Hi there, I can not really make out if youhave tried to locate and open your files through this method; Plug your mp3 into the computer through the usb cord. A window will appera in less then a minute (a fast computer it will be seconds) a window will appear asking you what you want to do with this'device"..Close that window (x). Click the "start" button on the screen (in one of the screens corners), a menu will drop down, click on "my computer". This will open up a window. In this window you will see numerous "discs" listed (for example, the harddrive is usually disc (c)...)I had a mp3 player that was under disc letter (f) and I've had a mp3 player that was under disc (e), I don't know why, but you need to open any "discs" you have. one by one (skipping disc (c) the harddrive usually). Once you open a disc you are looking for a folder (it could have the name of your mp3 on it, or it could be just some wild numbers, sometimes it's actually marked "music"). Just open any folders till you see the music, pictures or video's you are looking for, then you'll have found the folder to your mp3, now you can copy the song you want (or mp4 jpeg etc) and paste it in this folder and it will appear in your mp3...
Let me know how it went, , if you have anymore questions just ask me and I'll do my best...Don't forget to rate, thank you!
My NWZ-E344 Sony Walkman has copies of the sames songs on it.
Hi there Plug your mp3 into the computer through the usb cord. A window will appera in less then a minute (a fast computer it will be seconds) a window will appear asking you what you want to do with this'device"..Close that window (x). Click the "start" button on the screen (in one of the screens corners), a menu will drop down, click on "my computer". This will open up a window. In this window you will see numerous "discs" listed (for example, the harddrive is usually disc (c)...)I had a mp3 player that was under disc letter (f) and I've had a mp3 player that was under disc (e), I don't know why, but you need to open any "discs" you have. one by one (skipping disc (c) the harddrive usually). Once you open a disc you are looking for a folder (it could have the name of your mp3 on it, or it could be just some wild numbers, sometimes it's actually marked "music"). Just open any folders till you see the music, pictures or video's you are looking for, then you'll have found the folder to your mp3, now you can copy the song you want (or mp4 jpeg etc) and paste it in this folder and it will appear in your mp3.Ofcourse if you wanted to delete some doubles you can view and delete these now too.Let me know how it went, , if you have anymore questions just ask me and I'll do my best...Don't forget to rate, thank you!
Where does the charger fit in the device?
Hey
welcome to fixya. I hope u 'll be fine
- First see the charger holder keys that's what's they have style then see the device carefully from every side that how they have the catcher port of charger which is just in the shape of the charger.
- On the charger there is indication sign a arrow which shows from which side u have to insert your charger now hold the charger and carefully insert its pin in the the device port.
i hope problem 'll be solved. Enjoy
If u like this solution or way to solve the problem den please do
rate me.
THANKS
Sony walkman nwz a828 wont turn on
Have experienced similar issues to yourself. When I try to connect the bluetooth headphones the unit will not pick them up then, when ending bluetooth, the unit freezes. I found that pressing the reset button with a pin (on the rear) will turn the player on again. However, this has not yet solved the bluetooth connectivity issue.
I plugged it in to charge and it went into connect
Hi shannonaliot,
Walkmans are supposed to go into a non-responsive state when they're connected, no buttons would work and it'll only bear one line of "Connected" or something else - there is nothing unusual about this. It should work again when disconnected. But just a reminder - do not suddenly disconnect the device if it is not recognized as an MTP device.
My NWZ- A828K mp4 player wont turn on
how long have u used it? How did u recharge the battery? I think its the battery problem. Li Polymer battery should be managed differently. No complete discharge, No direct sunlight for hours... ect. U can switch the battery at the SONY or could do it by yourself. Get a battery from ebay.
My sony nwz-a828 won't turn on
I just bought mine yesterday and after turning it off whilst the bluetooth was disconnecting it would not turn on again. Then I pushed the reset button on the back and it has started working again.
