20 Most Recent Sony Walkman NWZ-A826 Digital Media Player Questions & Answers
7answers
How to download a song from youtube to cellphone
Step 1: Download a third party program to record internal audio directly, because native recorder can only record audio from outer devices like microphones or headphones. Step 2: Launch the program then hit "start" button. Play the video at the same time. Step 3: After video finishes, hit the button again to stop recording. Step 4: Edit music tags like artist, name, album, cover, etc. Here are 4 tools for recording YouTube music in detailed steps: https://www.leawo.org/tutorial/recording-music-from-youtube.html?qa=1409
6/11/2021 6:20:45 AM • Sony Walkman... • Answered on Jun 11, 2021
Play/pause button malfunction
Button stuck, disassemble, clean, reassemble, should be OK.
5/3/2015 4:20:25 AM • Sony Walkman... • Answered on May 03, 2015
No Power Cables
some units you can do depending on the quality of the unit as you can use a samsung charger on a xperia best way to know for sure is to take it into a shop and ask to check to make sure it works if it was me i would try the different charger doesnt matter what kind it is.
3/12/2014 5:18:13 AM • Sony Walkman... • Answered on Mar 12, 2014
Doesnt work
If you did Not Drop it and Pressing the Reset button on the back does not fix it. Then there is a possible short in the wiring inside, The Sony Walkman has had some issues of late with Quality control. Try pressing on the back panel with your 2 thumbs where the LCD and Button Controls meet. If you can get the power to turn on with the pressure between to two then there is a short that can be fixed. If you have the ability to open the Sony and do your own soldering. If you can not do that then you need a Sony Tech to open it and re-solder the wire that has come loose and is causing the short If that option does not work and if you no longer have warranty coverage you have a couple of options recycle it or throw it away and buy a new one. Or you can take it to a local Sony store and have them mail it to Sony. For this service you will have to pay 30 dollars for parts and labour to have them mail it in to Sony where Sony will ship you back a refurbished unit. The odds of you getting the same unit back are against you. You may get a refurbished unit as a replacement and that Refurbished unit may not even be the same colour as the unit you sent in for repairs. The refurbished Unit will probably be the Same model # as long as it is a unit they are still producing, if not then you may end up having to paying an additional fee for them to upgrade the refurbished replacement to a model they are producing. If you still have warranty coverage all you will need to do is pay the shipping and handling. Sony will replace the unit for free and may even upgrade you for free to there newest model if yours is a unit they are no longer producing. So for the Cost of having the item shipped to Sony you can get a brand new refurb unit Good Luck
1/27/2014 6:06:46 PM • Sony Walkman... • Answered on Jan 27, 2014
SONY WALKMAN NWZ-A826 AVAILABLE IN
Yes, its available at Rs. 12,345. Please check this link:
http://in.tolmol.com/SONY%20WALKMAN%20NWZ-A826%204GB%20MP3%20PLAYER%20WITH%20VIDEO%20PLAYBAK/prices/11633651
Hope this helps..
3/5/2011 10:09:17 AM • Sony Walkman... • Answered on Mar 05, 2011
How do i delete unwanted
To delete songs just plug it into your pc and the folder containing your songs will open. To delete the songs you no longer want hover over them and right click and delete.
To create playlists on your player with MediaMonkey (MM), you have to first create your playlists in MM and then tell MM to sync them to your player. To do this you have to do the following:
1 On the menu bar click on "Tools" > "Options" and then "Portable/Audio Devices" on the side list.
2 Select your player from the "Available Devices" list and then click on the "Configure" button.
3 Click on the "Auto-Sync list" tab and then the "Playlists" tab and a list of your playlists will appear. Click on the playlists you want synced to your player. When you sync your player, the playlists (and the files they contain) will be loaded on your player. The playlists will be placed in a folder called "Playlists".
8/22/2010 2:46:05 PM • Sony Walkman... • Answered on Aug 22, 2010
How to turn off nwz-a826
To turn the portable player on, press the Play/Pause button until the screen appears. To turn the portable player off, press and hold the Play/Pause button until POWER OFF appears.
To save the battery consumption, the player will do the following:
After turning on the power, if there is no operation or playback performed for about 1 minute, the power of the player turns off.
If there is no operation for a certain period of time while in stop mode, the display turns off automatically and the player enters standby status. If there is no operation for the next 30 minutes, the power of the player turns off.
7/27/2010 6:50:41 PM • Sony Walkman... • Answered on Jul 27, 2010
2answers
How do I create playlists? Thank you.
use sonic on creating playlist.
7/10/2010 12:14:26 PM • Sony Walkman... • Answered on Jul 10, 2010
Sony nwz-a826 pasiring with blueant z9
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
4/9/2010 5:51:08 PM • Sony Walkman... • Answered on Apr 09, 2010
When I go to listen to my mp4, it says
I started to have the same problem today and was also getting a "Library Error Encountered...." message. I was able to resolve it by Formatting my player. I lost all my data and settings but now I can put music on it again. To format your player go to the Home menu-Settings-Common Settings-Format
2/15/2010 9:46:35 PM • Sony Walkman... • Answered on Feb 15, 2010
2answers
I cant add any videos to it.
I guess the problem should be that ur MPEG-4 file is in wrong resolution ...You could try this Daniusoft video converter which is already optimized for output setting for sony walkman, easy-to-use.
1/25/2010 10:01:31 AM • Sony Walkman... • Answered on Jan 25, 2010
How does the bluetooth work?
well bluetooth is the new way to send information from device to device without wires or computer. When bluetooth is enabled on your walkman you can use something like your phone and turn the bluetooth on there and then transfer files to eachother, but you can also get wireless headsets, and you can use them wire free with bluetooth
1/1/2010 11:18:43 PM • Sony Walkman... • Answered on Jan 01, 2010
Finding it impossible to get videos onto my Sony NWZ-A826 MP4
Finding it impossible to get videos onto my Sony MP4 player - NWZ-A826. i fedup solving this problem kindly hellp me in this metter at earliest or take it back your product
10/15/2009 6:31:26 PM • Sony Walkman... • Answered on Oct 15, 2009
Sony Walkman NWZ-E438F connects & disconnects itself from USB
I suggest that you uninstall and reinstall the USB Driver to resolve the issue.
Follow these steps to uninstall the driver and confirm the player is recognized properly.
IMPORTANT:
  • This procedure must be performed while logged in as Administrator or to an account with Administrator rights.
  • If you are using the Windows® XP operating system, you must have Service Pack 2 or later installed.
  1. Click Start and then click Control Panel .
  2. In the Control Panel window, click Performance and Maintenance .
  3. In the Performance and Maintenance window, click System .
  4. In the System Properties window, click the Hardware tab.
  5. On the Hardware tab, under Device Manager , click the Device Manager button.
  6. In the Device Manager window, click the plus (+) sign in front of Disk drives .
  7. Click to select the Sony USB device .
  8. From the menu, click Action and then click Uninstall .
  9. In the Confirm Device Removal box, click OK .
  10. Disconnect the portable player from the computer.
  11. In the System Settings Change box, click Yes.
After that, restart the computer and reconnect the Player to resolve the issue. USB Drivers are generic to the Operating System and will reinstall automatically after restarting the computer. I hope it works.
9/22/2009 6:15:32 AM • Sony Walkman... • Answered on Sep 22, 2009
Sony Walkman NWZ- A826 Digital Media Player
try mtv.com tey might have some
7/23/2009 12:43:11 PM • Sony Walkman... • Answered on Jul 23, 2009
2answers
'Format not supported'
Hey.
I've just bought it and had a similar problem. What helped is:
1) Download Total Video Converter
2) In conversion format menu go to "Pocket Player."
3) Click "SONY Cellphone" and choose the middle line (Sony K700... blah blah)
4) Set the quality on "normal"
5) Low quality won't work - it'll say the file's not supported.
6) This worked for me. 45-minute video takes about 10 minutes to convert.
Hope it helps.
7/15/2009 12:20:02 PM • Sony Walkman... • Answered on Jul 15, 2009
SONY DIGITAL WALKMAN MALUFUNCINED
upgrade the firmware and try again
7/13/2009 9:57:06 AM • Sony Walkman... • Answered on Jul 13, 2009
Cannot reformat my mp4 sony walkman
u can use the initialize from the device itself or u can connect it to the PC and format
7/13/2009 9:07:26 AM • Sony Walkman... • Answered on Jul 13, 2009
3answers
Aparna
i use ImTOO 3GP Video converter convert to mp4 then drag and dropt to walkman video folder good lick
7/13/2009 9:06:16 AM • Sony Walkman... • Answered on Jul 13, 2009
Sony Walkman NWZ-A826 Digital Media Player Logo
Popular Tags
44 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Walkman Sony
  • Walkman Sony
Most Popular Question
play pause button malfunction
  • Audio Players & Recorders
