20 Most Recent
CorningWare Vintage Corning Ware Pyroceram Microwave Browning Grill or Questions & Answers
I need instructions for 10in. microwave browner
Only place I've found is here:
CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Can visionware go in oven
The short answer is YES!
In the 1990's Corning produced a series of Visions cookware, brown amber and cranberry colored glass-ceramic dishes and casseroles, that had the same basic properties of its white Pyroceram cookware. Visions cookware could go directly from freezer to hot oven to stove-top to the microwave oven to table to fridge to the broiler to the dishwasher, etc. Extreme temperature changes did not affect the very durable cookware, While many folks mistake Visions cookware for Pyrex bake-ware, they are not the same. Visions cookware was never issued in the forms (square pans, rectangle baking pans, loaf pans, pie pans, etc that clear glass Pyrex baking pans had been produced in for decades. In any case, Visions glass-ceramic cookware could go direct from the freezer to the hot oven - there would be NO DAMAGE to the cookware in such a practice. Visions glass-ceramic cookware also has markings to indicate usage. The majority of Visions cookware were of the "stove pot" design - stove top was intended from the start. However it is practical to let the food defrost first, or adjust the cooking time in order to create a better thoroughly cooked dish.
Yes, Visions cookware can be used in the oven! One caveat is that the pot lids are Pyrex which means that the pot lids can not be placed under the broiler (who does that anyway?), or under direct heat, or while hot on wet surfaces. The pot lids were meant to be pot lids - just like other Pyrex glass pot lids on most cookware.
What cause the high voltage fuse to damage
Based on the fact it is not said where it is used or how it blows i.e. does it blow as soon as power is applied or does it blow after a few seconds? In the first case you probably looking for direct short while in the second case a faulty item that is becoming defective when energized or hot.
My bowl is stuck on
I have the same problem now its the second time it got stuck. The manuals say not much. :(
My wave guide is terribly burnt. Can it be fixed or do I need a new microwave? Hisense- Model no: H25MOMS7H.
If your microwave's waveguide cover is severely burnt, it is generally recommended to replace it rather than repair it. The waveguide cover is designed to be transparent and protect the antenna or magnetron from food splatter and grease. To replace the cover, follow these steps:
1. Identify the replacement part number from your microwave's user manual or contact the manufacturer.
2. Order the part from the manufacturer, authorized dealers, or reputable appliance parts suppliers.
3. Turn off the microwave to ensure safety.
4. Remove the old waveguide cover and secure it using screws or clips.
5. Place the new waveguide cover in the same position and secure it using the appropriate screws or clips.
6. Test the microwave to ensure the new waveguide cover is in place and functioning correctly.
Replacement is crucial as a burnt or damaged waveguide can affect the microwave's performance and cause further damage to internal components. If you have any doubts or are uncomfortable with the replacement process, seek professional assistance or contact the manufacturer's customer support for guidance.
How might I set the clock on toshiba er7900
There are different patterns to setting a microwave clokc, depnding on the brand and age.Try these combinations (both with the door open and with door closed) to set the clock to 1:00:Clock > 1 > 0 > 0 > StartClock > 1 > 0 > 0 > ClockClock > Clear > 1 > 0 > 0 > StartClear > Clock > 1 > 0 > 0 > Start
My model number ogcmdm 11s2-10 how to replace broken door latch hook key P6OD17L-D1
It appears there might be a mix of information in the provided details. However, based on what you've mentioned, it seems you're dealing with a broken door latch hook key on a device with the model number "ogcmdm 11s2-10." Unfortunately, the information provided doesn't align with known model formats or specific products, and I might not have detailed information about this particular model or device.
Given that, here are some general steps you can follow when dealing with a broken door latch or lock:
- Identification of the Latch or Lock:
- Identify the type of latch or lock system used on your device. It could be a simple spring latch, deadbolt, or a more complex mechanism.
- Obtain Replacement Parts:
- If the latch hook key is broken, you may need to obtain a replacement part. Contact the manufacturer or a supplier to inquire about replacement latch hook keys or the entire lock assembly if necessary.
- Accessing the Broken Part:
- Depending on the design of your device, you may need to disassemble or remove certain components to access the broken latch or lock. Refer to the device's user manual or any available documentation for guidance.
- Remove Broken Parts:
- Once you have access to the broken latch or lock, carefully remove the broken parts. This may involve unscrewing screws, removing panels, or disassembling components.
- Install Replacement Parts:
- Install the replacement latch hook key or lock components following the manufacturer's instructions. Ensure that the new parts are compatible with your device.
- Test Operation:
- After replacing the broken latch or lock parts, test the operation to ensure that the door can be securely locked and unlocked.
- Reassemble:
- If you had to disassemble any components to access the broken part, reassemble the device according to the manufacturer's instructions.
If you encounter difficulties during the process or if you are unsure about how to proceed, it's advisable to contact the manufacturer's customer support for specific guidance or consider consulting with a professional technician.
Please note that the general steps provided may not cover all possible scenarios, and the actual process might vary based on the specific design of your device.
