20 Most Recent
Dacor MWO30S Millennia Series Warming Drawer Oven with 1.55 Cu.Ft Interior Capacity, Stainless Steel, 4-Hour Timer, Timer Override, Moisture Control, Full Extension Drawer, Moist/Crisp Selector, Temperature selection 100-200, Sabbath Compliant STAR-K Certi Questions & Answers
Dacor DCM 24. Everything, clock, fan, rotator, light all come on but oven and microwave don't heat?
On model DCM24, that's usually a defective bottom door switch, or its mount is loose, misaligned, or broken.
The service manual is
here, and my help file on door switches is
here.
For free DIY and other help and advice, feel free to contact me via my site.
Always include your FULL model number*, FCC ID number*, and detailed symptom information.
* from the tag in the cooking cavity or elsewhere on the oven (or send a clear photo of tag)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Dacor DMT2420S
That would be your waveguide cover. If damaged or discolored, the waveguide cover has been damaged by heat and must be replaced.
It protects your waveguide and magnetron from arcing due to grease and food particles.
The area of the waveguide behind the waveguide cover should be clean, and if rust or flaking is present it must be sanded, then repainted with high temperature appliance paint.
For Dacor model DMT2420S, the waveguide is part number
66345 and you can get it from
The Pros here for $11.07 (subject to change).
The service manual is at my site here:
http://www.microwavecontrol.com/dmt_2420_sm.pdf and the part list is here:
http://www.microwavecontrol.com/dmt_2420_parts_list.pdf.
Feel free to e-Mail me at
[email protected] if you need more free advice.
Microwave does not heat and makes a lot of noise
hi Richard, from experience i would say the power supply to the magnetron is at fault, you must take extreme care if you intend to test the supply as the high voltages involved...
Regards
Rob
