20 Most Recent Bionaire BAP825-U Air Purifier Questions & Answers
Why is it not running? Motor defective? Receiving power? Device that switches power to motor working? You have to localize the issue before shopping for parts.
Bionaire... | Answered on Aug 31, 2017
there should be a pin hole at the top of the unit by the lights and power button. you will need like a sewing needle to put in there. hold for about 5 seconds and the unit will reset. if that doesn't work. you need to turn off the unit unplug it for about 10 seconds and plug back in. if that doesn't work please let me know.
Bionaire... | Answered on Mar 18, 2010
there should be a tiny in hole at the top of the unit. when the unit is on put a pin inside that hole and hold it for about 5 seconds. then release the unit's lights will all come back on and then it should be reset as if you just turned the unit on. if that doesn't work please let me know and i will see what else i can do for you.
Bionaire... | Answered on Aug 23, 2009
the sparking of the purifier by the plug is NOT good. it can be a fire hazard. there is a short within the switch. the best thing is to make sure that your under warranty and then call the manufacturer to get a replacement.
Bionaire... | Answered on Aug 20, 2009
I do apologize for the inconvenience, the best way that i can tell you to fix the light is that there is a tiny pin hole on top of the unit. that's a reset button. you need a small needle or something that will fit in there. hold it down for about 3 seconds. your unit should reset. the light sometimes comes on with new filters cause it hasn't recognized that they are new yet. if that reset doens't work please let me know
Bionaire... | Answered on Aug 19, 2009
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Sounds like it needs a good cleaning. Does this one have the metal bars that pull out? I have a ionic pro and when it gets dirty it will emit small sparks where the dust connects from one bar to the other. It also has a pull up wand that cleans the wire that help build the charge. If this is the system that changes the charge on the ions to attract them to plates, you will see small sparks when it becomes dirty. Mine always let me know by the sparking sounds it makes.
Bionaire... | Answered on Dec 17, 2008
Noggin's solution is correct.  My copy of the BAP825 manual says to poke a paper clip into "the hole marked RESET."  There is no hole marked 'reset' on the air cleaner.  Thanks, Noggin!
Bionaire... | Answered on Mar 02, 2008
Google (bionaire)(f70s)(manual) without parens.
Bionaire Air... | Answered on Jun 04, 2019
Bionaire BAP825-U Air Purifier Logo
Popular Tags
15 questions posted
Top Bionaire Air Purifiers Experts
john h
ray gallant
Kardoc
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Bionaire Air Purifiers
Most Popular Question
reset light indicators after replacing
  • Air Purifiers
