20 Most Recent True Display Refrigeration GDM-35F Questions & Answers
change the fan motor, if the fan dont wonrk wont spread cool air
True Display... | Answered on Sep 20, 2014
The heat at the opening of refrigerator is usually a sign the condenser coils are dirty. Check the condenser coils for a restriction underneath the unit. Dirty condenser coils will cause poor air flow over the coils and compressor. Poor air flow will cause a lot of problems, including overheating the compressor, the refrigerant and the copper lines. This will destroy your sealed system. The coils need cleaning at least once a year, more often if you have pets.
I couldn’t determine if your unit has an “energy saver” setting. If so, turn it on. Not all refrigerators have energy saver. This is on units with emilion heaters in the wall around the door gaskets. The heaters are to eliminate condensation around the door. Turning ON energy saver turns OFF those heaters. You should notice a change quickly if it’s the heater causing the heat, that is, if you have that model.
Cleaning the coils will need a day or two to allow things to cool down before you notice a change in the heat around the door.
True Freezers | Answered on Jul 29, 2019
I am assuming you are relating to the evaporator fan(s) not running. If this is the case, some units have a 'Klixon" type thermostat in the evaporator so when the evaporator coil temp reaches a predetermined temperature, the fans come on. You may have a bad "Fan Delay" (Klixon) or the coil is not reaching the proper temp to activate it to turn on the fans. I would check the wiring diagram on the unit for this part to see if this unit has it in the system.
True Freezers | Answered on Jun 12, 2018
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-T-23_iom.pdf
This web site has the manual for this freezer. Take a look and see if this answers your question.
True Freezers | Answered on Sep 11, 2017
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-T-23_iom.pdf. Check out this manual. has instructions.
True Freezers | Answered on Feb 11, 2017
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-T-23_iom.pdf. check out this manual. has instruction for lots of what you want.
Only from the manufacturer.
True Freezers | Answered on Nov 03, 2016
if seals are in good condition
no sizable water leaks from cabinet
one should suspect the thermostat is no shutting off compressor
test or replace thermostat
True Freezers | Answered on Oct 08, 2016
Dirty coils, or refrigerant getting low
True Freezers | Answered on Nov 11, 2015
Most all true units have digrams on the unit. May have to pull covers to find them
REPLACED COMPRESSOR ON FREEZER TRUE AIR 3/4 HORSE POWER 115V
True Freezers | Answered on Sep 16, 2015
True Display Refrigeration GDM-35F Logo
1 questions posted
Top True Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
J Rosado
Are you a True Freezer Expert? Answer questions, earn points and help others
View Most Popular
True Freezers
  • True Freezers
Most Popular Question
true gdm35 evaporator fans not working
  • Freezers
