20 Most Recent Silver King SKP4812/C2 Refrigerated Prep Table Questions & Answers
Are you getting any noise at all from the back of the system. It sounds like it could be a bad t'stat or relay. This would stop it from working right away.
Silver King... | Answered on Feb 06, 2013
we have no way of knowing that
Freezers | Answered 4 hours ago
Orange light means it cannot cool properly. I would get it checked by a competent refrigeration engineer.
Freezers | Answered 3 days ago
The green light may have failed without affecting operation.
Freezers | Answered on Feb 06, 2021
It's a freezer. The temperature should be minus 18.C, yours is showing 0'C. It is telling you the freezer is 18' hotter than it should be.
https://www.defy.co.za/amfile/file/download/file/166/product/1996/
Freezers | Answered on Jan 10, 2021
Check with an appliance parts supplier to determine whether the Ranco unit is a specified replacement for the Beaumark. Also, it is possible that the Ranco thermostat is defective, though new.
Freezers | Answered on Jan 01, 2021
Probably the blinking green light is an indication that something is wrong with the compressor or a related component.
Freezers | Answered on Dec 14, 2020
That unit is surprisingly clean. It may have had the fan module that you can see in picture, replaced and whomever replaced it, did not put the lug back on or it was not there with the newer unit.
Freezers | Answered on Nov 21, 2020
Clicking sound is overheat at the compressor. There is a device called a Clixon that is cutting and restarting. Remove covers and clean the condenser grill with a vacuum cleaner and brush.
Freezers | Answered on Oct 18, 2020
these units are usually set up to have the beater rotate in a clockwise direction facing front. If they get stuck, it is usually due to excessive wear or the hexed end has been lubed and has created a suction seal in it's counter part. Try rotating the beater in a counter clockwise direction while holding the drive wheel pulley stationary. Be sure to unplug unit first. this has worked for me in the past but can be very difficult at times.
Freezers | Answered on Oct 09, 2020
Too high of water pressure letting in more water then it can drain off. Try turning down the water first
Freezers | Answered on Sep 28, 2020
either a t-stat issue or if it does not run for more than a few seconds, your compressor is done for.
Freezers | Answered on Sep 15, 2020
I Need two panels replaced on my Walkin Cooler, is there anyone that cacn give me a quote/price for this repair
Freezers | Answered on Sep 13, 2020
Silver King SKP4812/C2 Refrigerated Prep Table Logo
1 questions posted
Top Silver King Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Silver King Freezer Expert? Answer questions, earn points and help others
View Most Popular
  • Silver King Freezers
Most Popular Question
silver king skp4812 stopped working
  • Freezers
