20 Most Recent Whirlpool GSS30C6EYW 30 cu. ft. Side-by-Side Refrigerator with Tap Tou Questions & Answers
are both door leveled? if not the door cam worn out and need replacement
Whirlpool... | Answered on Nov 23, 2017
The more snowflakes, or the larger they are, the colder.
The manual states.
Adjusting the temperature control
Turn control to a higher number for colder
temperatures.
Turn control to a lower number for less cold
temperatures
The manual is here
https://www.searspartsdirect.com/manual/5fkla8zmox-001198/whirlpool-wzf79r20dw00-upright-freezer
Whirlpool... | Answered on Jul 05, 2019
The door switch or door module is defective. or the door is not fully closed
Whirlpool... | Answered on May 10, 2019
CALL A REPAIR SERVICE LOCALLY . NO DOUBT IT NEEDS FREON AND ONLY PRO'S CAN DO IT FOR YOU
Whirlpool... | Answered on Apr 22, 2019
http://www.fixya.com/tags/freezer_green_light_flashing/browse/whirlpool
Whirlpool... | Answered on Mar 13, 2019
That is a compressor overload chime by the sounds of it. That is why the compressor stops. It is telling you needs attention to stop complete failure of the compressor. Try cleaning fluff out of the compressor coils with a vacuum cleaner.
Whirlpool... | Answered on Feb 06, 2019
The defrost water from the melted frost (ice) collects in the bottom of the freezer. If there is no plugged up drain, then you must remove the water manually with a sponge and bucket after a defrost cycle.
Whirlpool... | Answered on Jan 24, 2019
If it’s in floor if freezer, you have a clogged defrost drain. If it’s on inside back freezer wall, it’s a defrost problem
Whirlpool... | Answered on Jan 23, 2019
The solenoids that operate the ice maker and the water dispenser in the door may be getting water internally. I would put a pressure regulator on the line of the pressure exceeds 30 PSI.
Whirlpool... | Answered on Jan 23, 2018
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Whirlpool... | Answered on Jan 02, 2018
All cooling/heating appliances must have a functioning device to control the rise and fall of temperature.
Whirlpool... | Answered on Dec 31, 2017
The freezer is where the cold air is generated. It knows that is not logical to turn off the fresh food side so it determines that it needs the cold from the freezer side, so it over rides the error and will attempt to start. Turn your freezer on to a mid way setting ans give it a few hours to comply.
Look behind the kick plate at the bottom of the unit. Take it off, using either clips or screws holding it in place.
Whirlpool... | Answered on Dec 12, 2017
-You mean you want to switch the hinge from one side to the other side ?
-I don't think so.
Good luck
Mai
Whirlpool... | Answered on Nov 08, 2017
This unit has several fan motors, it could be one of them. If so you may have to replace the motor
"Always disconnect power before trying to repair any appliance."
Whirlpool... | Answered on Oct 23, 2017
Whirlpool GSS30C6EYW 30 cu. ft. Side-by-Side Refrigerator with Tap Tou Logo
1 questions posted
Top Whirlpool Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
jasbo
jasbo
Dennis Boxerman
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Freezers
  • Whirlpool Freezers
Most Popular Question
whirlpool fridge door drops into place
  • Freezers
