20 Most Recent Frigidaire FFHS2622MS 26.0 cu. ft. Side by Side Refrigerator with SpillSafe Glass Shelves, Gallon Door Bins, Humidity-Controlled Crisper and External Ice/Water Dispenser: Stainless Steel Questions & Answers
Hey Dunstin, thank you for your inquiry!
From what you have described your Frigidaire refrigerator is dispensing ice at random times. This could be a miscommunication within the control panel and I would recommend performing a reset. You can reset your refrigerator by disconnecting power from it for at least ten minutes. If you continue to experience an issue with your ice dispenser I would suggest contacting a professional technician for proper assistance with repairs. I hope this information is helpful to you. -Matt
Frigidaire... | Answered on Feb 03, 2016
Hello Debby Rhodig, thank you for your post!
Based off the information for your Frigidaire refrigerator I see that your fresh food side is not cooling and the alarm is going off. I would check to verify there is no food or packages blocking the rear vent. If there is nothing blocking the vent place your hand back there to check if you feel any cold air coming out of the damper. If there is no cold air coming out of the damper it could be an issue within your evaporator fan, if there is cold air coming out I would set your temperature to a colder setting.
Changing the temperature inside your appliance can take up to 24 hours to stabilize. If you continue having issues with your refrigerator I would seek assistance from a professional to come out and properly diagnose and repair your appliance. I hope this helps. -Matt
Frigidaire... | Answered on Aug 20, 2014
Hello Friend, this is Z. Thank you for allowing me to assist you!
Did your refrigerator previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your refrigerator by unplugging it or flipping the household circuit breaker. It is good to wait roughly ten minutes and then turn on your refrigerator. After deactivating the alarm and your refrigerator has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your refrigerator may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. Best regards!
Frigidaire... | Answered on Aug 19, 2014
you checked your cooling system.
Frigidaire... | Answered on Mar 26, 2013
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
Frigidaire... | Answered on Oct 23, 2019
Always at least and inch or two away from wall.
consult your installation instructions or use guide for info
Frigidaire... | Answered on Jun 24, 2019
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
Frigidaire... | Answered on Jun 16, 2019
Freezers expel warm air. There should be no 'blowing' inside. If it is expelling warm air, then it is working fine, eventually the expelled air should get cooler and cooler.
Frigidaire... | Answered on Jun 06, 2019
That yellow light on sonne older modelks is just showingbtge power is on. I never heard of a chest freezer having a "quick freeze" feature. This feature would also require forced air cooling and auto defrost. If the walls get frost on ghr m t hen Im betting that is ju st a power light although it may say freeze or something else like that. Its just so when you see the yrllow light you know there is power.
Frigidaire... | Answered on May 20, 2019
Typically, error code "HI" (the customer may say "H1") on a Frigidaire refrigeratorunit indicates that the unit has detected high temperature in the freezer and/or therefrigerator https://kb3.s2g.net/index.php?/article/AA-00411/0/Frigidaire-Refrigerator-Unit-Flashing-HI.html
Frigidaire... | Answered on Mar 29, 2019
Frigidaire FFHS2622MS 26.0 cu. ft. Side by Side Refrigerator with SpillSafe Glass Shelves, Gallon Door Bins, Humidity-Controlled Crisper and External Ice/Water Dispenser: Stainless Steel Logo
8 questions posted
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
last week fridgidaire ffhs2622ms control
  • Freezers
