20 Most Recent Blodgett DFG-100 Gas Single Oven Questions & Answers
Check out www.stovedecals.com - they can provide replacement stove decals for most major models and brands! They operate in Florida and manufacture the decals in the USA!
Blodgett DFG-100... | Answered on Dec 29, 2018
Request the wiring diagram directly from Blodgett.
Blodgett DFG-100... | Answered on Mar 19, 2018
You need at least 24 volts for the gas valve to open
Blodgett DFG-100... | Answered on May 03, 2016
Defective thermocouple.
Blodgett DFG-100... | Answered on Nov 01, 2015
that is a door switch which locate bottom of panel. If that close ignite will ignite, if the door open the pilot will stop. Hope it help ..good luck
Blodgett DFG-100... | Answered on Jan 25, 2015
Check the door switch to see if it is making contact. It is located inside the front cover on right hand side, next to the chain sprocket.
Blodgett DFG-100... | Answered on Oct 17, 2014
open burner panel and checked for door switch first ....good luck
Blodgett DFG-100... | Answered on Sep 24, 2014
After burner on did you hear any spark ignitor if that your flame sensor is dirty or need to replace....good luck
Blodgett DFG-100... | Answered on May 06, 2014
to confirm check the Ohm draw on the temperature probe, i am not sure what is the correct one but you can check online at blodgett if probe okie then you will have an issue with the temp controller there possible the potentionmeter is worn out.....good luck
Carbon monoxide is both odor- and colorless, making it very dangerous. It has no characteristic odor.
Blodgett DFG-100... | Answered on Dec 27, 2011
Blodgett DFG-100 Gas Single Oven Logo
74 questions posted
Top Blodgett Ovens Experts
Dennis Boxerman
Marvin
Marvin
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
View Most Popular
Blodgett Ovens
  • Blodgett Ovens
Most Popular Question
igniter stays lit entire time oven
  • Ovens
