20 Most Recent KitchenAid K45SSWH model 45SS Classic Stand Mixer, Mixer Style Tilt-head, All-Metal Construction, Direct Drive Transmission, Bowl Finish Brushed Stainless Steel, Motor Wattage 250 Watts, Flour Power 8 Cups, Mixing Bowl Capacity 4-1/2 Quart, Planetary Mixing Act Questions & Answers
Remove the brush caps on the sides of the motor housing and check the carbon brushes. If they are worn out replace them. They are keyed and will only fit properly one way so be observant. If that's not the problem remove the back cover and check for broken wires on the black control plate. Make sure the switch on the bottom inside of the control plate is making contact. If still faulty check the cable for continuity to the control plate, cable connects to the black wire and the white wire on lower left of control plate. After that you need to check for continuity of the field coil windings. Only thing left after that would be the phase board pcb just above black speed control plate at the back.
KitchenAid... | Answered on Sep 07, 2014
I am unfamiliar with the types of plug and socket you refer to - we use a different standard in the UK though the principle is identical.
An appliance with a metal body would usually require a ground connection though if the electrical parts are double insulated a ground connection could be deemed an unnecessary safety precaution.
Firstly is the rated voltage of the mixer the same as your supply? Assuming it is correct, is the power cord 2 core cable or 3 core?
If it is 2 core the mixer has a fault as the metal body should not be live (or hot).
If it is 3 core is is possible either the plug is internally connected wrongly, the power cord is connected wrongly inside the mixer or the mixer electrical system is faulty and your power outlet doesn't have an effective ground connection.
If your consumer unit (main fuse and breaker box) complies with modern standards, the ELCB or RCD should have tripped as soon as you plugged in your mixer.
KitchenAid Food... | Answered on Aug 29, 2020
I would guess you have sheared a shear pin somewhere in the drive and there is enough tension to turn it.
Parts 18, 22, 25 are all shear pins
https://www.searspartsdirect.com/model/36d50tlrzh-000593/kitchenaid-k5ss-stand-mixer-parts
KitchenAid Food... | Answered on Aug 26, 2020
My wife has the same model and the planetary unit fell off shortly after we bought it. Since we had moved overseas to a remote pacific island, getting it fixed under warranty was out of the question.
Since the rotary unit is a pressue fit, I pressed it back into place and it worked fine for about 3 months before I had to repeat the process. After that it became a monthly ritual.
I finally decided to fix it for good. What I did was drill a 3/8" hole in the center of the nub in the middle of the inverted rotary cover plate. I then drilled a 5/16" pilot hole in the center of the grooved shaft that the rotary cover plate presses onto. I then tapped that hole with a 18 NC tap. I was careful to tap it just a little shy of the depth of the cap screw that I was going to insert into the threaded hole so that it would jam as I tightened it. I then greased all the gears with a white machine grease and pressed the roary cover plate back onto the shaft. I then put a washer on a 5/16"-18 x 1" socekt head cap screw and clamped the thing together. It hasn't come off in the last 2 years.
While I am moderately skilled in this sort of thing it wasn't a precision operation. Since I was living in a fairly remote location with no shop, I did the entire operation on the kitchen counter using a handheld electric drill. Probably the hardest part was determining how deep to tap the shaft. I did it by trial and error. You can adjust the depth by using a washer or two of varying thicknesses.
I'm really surprised how lame a design using a press fit for this assembly is. They could easily prevent the problem by using my approach or even putting a cotter pin through the shaft and reciever tube in the rotary cover plate (a small hole would be needed in the side of the tube to set the cotter pin).
From what I've seen on the internet while looking for a solution, this is a fairly pervasive problem.
We thought we were buying a high quality machine that we thought would be reliable in our remote situation. Fortuantely, other than the falling rotary cover issue, the machine has worked great.
KitchenAid Food... | Answered on Jul 14, 2020
what do you mean by "slip"
the blades quit turning?
or slow down?
or lose power?
or out of alignment?
in other words how do you know they are "slipping"?
KitchenAid Food... | Answered on Jun 10, 2020
You can buy direct or get from other vendors including eBay.
Replacement Parts - KitchenAid
www.kitchenaid.com > replacement-parts
Find KitchenAid® stand mixer attachments, plus other stand mixer accessories and countertop add-ons for our hand mixers, blenders, food processors and coffee ... Missing: K4- ‎' Must include: K4-
KitchenAid Stand Mixer Parts - The Mending Shed
www.mendingshed.com > shop > KitchenAid-Stand-Mixer-Parts
Results 1 - 30 of 422 - KitchenAid Stand Mixer Beaters - Hooks - Whisks · KitchenAid Stand Mixer Bowls - Shields - Covers · Repair Parts by Model/Mixer ...
KitchenAid Collectible Kitchen Mixers for sale ' eBay
www.ebay.com > ... > Mixers > KitchenAid Collectible Kitchen Mixers
Results 1 - 48 of 67 - Kitchen Aid Hobart Model 3-B Stand Mixer Beehive Bowl S-24263 ... Kitchenaid Mixer food grinder replacement parts All six discs plus 3 ...
KitchenAid Food... | Answered on Jun 01, 2020
Worn carbon motor brushes typically cause motor sparking when you're running the mixer. Unplug the stand mixer and examine the motor brushes for wear. To remove a motor brush, use a screwdriver to unscrew the motor brush cap. Pull the cap and the carbon brush out.
Thank you for using Fixya.
KitchenAid Food... | Answered on Apr 13, 2020
The blades will need to be removed and cleaned. Make sure. Always make sure to Unplug your mixer before taking apart
KitchenAid Food... | Answered on Apr 06, 2020
there are many websites that are offering this just search it on google I have got delivered many of the things form different websites apart from that I use https://verifiedcouponcode.com/ to get free discounts and to many of the websites and this help me a lot to get numerous products for my household.
KitchenAid Food... | Answered on Feb 14, 2020
KitchenAid K45SSWH model 45SS Classic Stand Mixer, Mixer Style Tilt-head, All-Metal Construction, Direct Drive Transmission, Bowl Finish Brushed Stainless Steel, Motor Wattage 250 Watts, Flour Power 8 Cups, Mixing Bowl Capacity 4-1/2 Quart, Planetary Mixing Act Logo
2 questions posted
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Mixers
Most Popular Question
kitchenaid mixer turn
  • Food Mixers
