20 Most Recent Childesigns Carrollton Crib Questions & Answers
I was just given this exact crib from a family member but they lost the instructions. Would you be willing to sell me a copy? Please let me know. These are hard to come by. Thanks so much!
[email protected]
Childesigns... • Answered on May 09, 2016
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
[email protected]
Childesigns... • Answered on Sep 24, 2013
i have located a manual off the internet someone scaned to me. i dont know if it is exactly the right crib. the one that was given to me looks like a carlton or shelby design. i need the screws for it and the size was on there along with the instructions,the screws fit great. i can send it to you if you still need it just email me at [email protected]
What do they look like?
Childesigns... • Answered on Sep 23, 2013
with the indulgence of robotek....
Could you pls post an image/picture of the defective part (right crib lock)?
Perhaps you can also try here, here or here.
Hope this be of Additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
I am not familiar with this crib, but I have been through many cribs and they all (so far) are adjustable to lower the mattress. You can figure it out by removing the mattress and matress board and inspecting the way the board is connected to the frame. Often there is a bar or rung that sits in a clip or groove at each corner of the crib just below the matress board. You may have to crawl underneath and look up at it. Usually you will be able to lower the platform without using tools, but be sure to take the weight off the platform by removing the mattress and board. Good luck.
Converting the crib to a toddler bed?
yes you need to get the conversion rail. I'm looking for one if anyone can find one. I can't find a number for the manufacturer and the store I bought it from doesn't carry it anymore.
This company has gone out of business,but you could try various buy/sell sites,yard sales,secondhand stores,etc.
Nod-a-way cribs go together about the same way as the rest. If you have 2 metal rods
those hold the front-dropdside and allow the dropside to move safely up and down.
The back will have either 4 bolts, 2 on top-2 on bottom or a nub that holds the top side
of the back-fixed rail with 2 bolts on the bottom. The mattress support will either bolt in,
slide into opennings on the head and footboard. The hard thing is getting the dropside
set right so that it drops when you push the release with your foot. Be sure to lift then push
with your foot. Let me know if any of yours is different. I'll try and help more.
Childesigns... • Answered on Mar 29, 2011
Use the allen wrench that came with the crib to slightly loosen the two bolts on the moveable gate side (bottom) then shimmy the sliding gate out of the tracks. I did it myself with verbal directions from the store - should be easy. If I find the instructional guide, I tell you.
Childesigns... • Answered on Aug 12, 2010
i could suggest that you go to a Welder so that he/she can made a duplicate metal piece that is missing.
hope i helped you
here are a website if you need some mattress on your crib:
http://www.bestmattressreviews.com/
Childesigns... • Answered on Feb 02, 2010
I recommend you contacting one of the highly trained CSR's at Products America. They will be able to go over your crib with you and determine what is missing and may even be able to provide you with the missing part. The numbers are 800-205-9642 or 800-772-1041. Call them anytime Monday through Friday from 8am to 6pm CST.
Childesigns... • Answered on Jul 31, 2009
Childesigns Carrollton Crib Logo
39 questions posted
Top Childesigns Baby Gear Experts
john h
ray gallant
Tom Chichester
Are you a Childesigns Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
  • Childesigns Baby Gear
Most Popular Question
appears some parts
  • Baby Gear
