20 Most Recent Intuit QuickBooks® Pro 2006 Full Version for PC (5 User/s) Questions & Answers
3answers
I have lost my quickbooks
Yes! You can contact Intuit from their website and ask them to send you a link to download QuickBooks pro2006. You can verify your purchase of the software by telling them what your license and product numbers are. When you finish downloading the program it will ask you for both numbers in order to register the software before use.
10/14/2022 12:18:54 AM • Intuit... • Answered on Oct 14, 2022
Altering an existing Invoice / Purchase order to make the data cells larger
It depends on which program this template is in. If it's an excel spreadsheet it's very simple to extend each cell. If it's a regular sheet, perhaps the margin could be adjusted to have a little wider print area.
9/24/2017 1:23:33 AM • Intuit... • Answered on Sep 24, 2017
I want to back up a 2nd copy of a quickbooks pro
You need to make the backup from quickbooks using file, backup. Select the drive you want the data stored on. Then if you need the backup data you need to use file, restore. you are only backing up the data so you have to run the file from the program, with the restored data.
9/21/2017 2:00:37 AM • Intuit... • Answered on Sep 21, 2017
This notice is comming up on every thing I do " this modification will affect transactions from closed peroids
There has been a closing date entered in the software. You would need to remove the closing date to prevent the message.
12/23/2014 6:41:43 PM • Intuit... • Answered on Dec 23, 2014
After entering product codes nothing happens
Try for these step
  • Ensure you meet the Minimum System Requirements
  • Reboot and temporarily disable antivirus software
  • Try to restart your Computer and try again
  • if you product number is break then contact for new one.
If you need any help while any problem during this process follow Intuit Tech Support .
8/29/2014 12:13:25 PM • Intuit... • Answered on Aug 29, 2014
Quickbooks activation 2006
This version is no longer supported, and I believe intuit no longer has the capability of creating the validation codes for it.
12/12/2013 7:06:20 PM • Intuit... • Answered on Dec 12, 2013
I can not activate QuickBooks Pro 2006, Please
Your only solution is to call Quickbooks help. Give them your license number and they will be able to walk you through how to re-activate your license.Note: If you are attempting to install quickbooks on a second computer and you purchased a one user license, that will be the reason. They will make you pay for another license. You can only load Quickbooks single user license on one computer.Hope this helps.
11/19/2013 3:26:14 AM • Intuit... • Answered on Nov 19, 2013
I recently uninstall quickbooks Pro 2006 and
support.quickbooks.intuit.com/Support/Articles/HOW12628 -
Try this , hope it helps .
3/10/2011 10:40:13 AM • Intuit... • Answered on Mar 10, 2011
Cannot find how to change closing date
Open QuickBooks then go to "edit" at the top left side of the page. This will open a drop down list. Then go all the way down to the last choice which is "preferences". Then choose "accounting" This will open two choices - my preferences on one tab and "company preferences" on the other. Choose company preferences and you will find a place there to set the date that the books are closed through. Enter your date and then hit "ok" and close the preferences area. The software will change the date and tell you where to go from that point.
9/8/2010 10:34:55 PM • Intuit... • Answered on Sep 08, 2010
How to i activate quickbooks 2006
There is no support including registartion for 2007 and older versions. You have to upgrade to a new version.
www.cpahispano.com
8/8/2010 4:31:04 PM • Intuit... • Answered on Aug 08, 2010
How can I buy QuickBooks 2006?
Did you mean Quick books 2006 Application?
You can purchase the copy of QuickBooks Pro 2006 [OLD VERSION] via ONLINE [AMAZON.com]
go here:
AMAZON.com
Let me know for any clarifications.
4/6/2010 12:07:43 PM • Intuit... • Answered on Apr 06, 2010
VAT registration number on invoice is incorrect
Try this web-site:
www.quickbooks.com/keycode
2/2/2010 1:31:05 AM • Intuit... • Answered on Feb 02, 2010
What function does the ctrl key and the
select all
10/6/2009 6:02:21 AM • Intuit... • Answered on Oct 06, 2009
Quickbooks Pro 2006 loads and then errors after signing in...
Try reinstalling software. You may go to Control Panel, Add Remove Programs and click on Repair or insert CD and click on Setup
6/25/2009 11:26:49 AM • Intuit... • Answered on Jun 25, 2009
Problem loading Quickbooks
Hi Mike,
First try reboot your machine, in case an update required a restart.
If that doesn't fix the problem, the next step would be to go to the task manager (Ctrl/Alt/Del) and go to the processes tab. Scroll down to QBW32.exe, highlight it and then click End Process (at the bottom right), then click file and exit.
Restart quickbooks from the icon by right clicking and clicking open. Do this only ONCE, hit it more than once will make Quickbooks attempt to start multiple times. Give the program time to launch.
If this doesn't work find the reboot.bat file (do a search for this if you can't find it in the quickbooks folder) - double click on it to run it. Once that is complete try again to restart Quickbooks.
If you are still having trouble you can try a a repair of quickbooks (2006 and higher). Go to the Control Panels, add remove programs, scroll down to quickbooks and click on Change remove button, choose the repair option.
If this doesn't work, you will need to do a clean install - (be sure to copy your quickbooks files to a remote disk or into another file (my documents would be a good place to put them if you have to put them on your hard drive) - If you get to that point ask about doing a clean install and I will be happy to walk you through it -
2/6/2009 4:06:35 PM • Intuit... • Answered on Feb 06, 2009
Blue line appears in the
The problem has been solved!!! Thanks to your premium assistance plan. The crn was willing to stay with me until we figured out this problem.Thanks to him and many trials and errors we found out that a future date had been placed on past checks. Thanks again for the help!!
1/21/2009 4:52:23 PM • Intuit... • Answered on Jan 21, 2009
User's guide?
check the CD ROM, I believe the manual is on there in a PDF file
1/8/2009 11:15:32 PM • Intuit... • Answered on Jan 08, 2009
3answers
Intuit Error 15243
Intuit Error 15243
QuickBooks Error 15243 by Dylan on January 27, 2019 in QuickBooks Help 0 QuickBooks Error 15243 Overview QuickBooks error code 15243 usually pops up on the screen when the user is trying to update QuickBooks Desktop or is downloading latest payroll update. QuickBooks error 15243 may also show up when exporting transactions to excel. 15XXX series is very common series of errors in QuickBooks desktop. Usually, users get it fixed by applying simple troubleshooting steps provided by experts. The ugly thing about errors like QuickBooks error 15243 is they affect the workflow. Sometimes users get stuck in resolving these errors on their own. In these circumstances, users should get in touch with QuickBooks tech support experts to resolve their concerns quickly. Causes of QuickBooks Error 15243 The various causes due to which QuickBooks error code 15243 occurs are mentioned below: ·Incorrect QuickBooks installation ·Intuit QuickBooks File Copy Service (FCS) is damaged ·QuickBooks FCS service is not enabled ·QuickBooks Payroll subscription has ended ·Damage in Company File ·User not logged in as an Administrator QuickBooks Error 15243 - Intuit FCS Service is Damaged QuickBooks Error 15243, while updating QuickBooks desktop appears on the screen stating Error 15243: Intuit FCS Service is Damaged. This is because of the Intuit File Copy Service is disabled. Disabled FCS service is causing the error to update QuickBooks desktop. Intuit FCS service is an essential add-on service which manages file transfer during your QuickBooks desktop update. Below-mentioned steps are troubleshooting steps to resolve QuickBooks error 15243. Also helps when Intuit FCS is damaged.
Resolve QuickBooks Error 15243 in QuickBooks Desktop
·End all open QuickBooks windows and close the application ·Go to the Start button ·Right-click on Computer/This PC ·Choose Manage option ·Go to Services & Application Tab ·Double Click on Services option ·When you see Intuit QuickBooks FCS, click on it ·Click on the General Tab ·Click on Startup ·Choose the Manual option ·Click on apply ·Choose Start & then Ok ·Now, Reopen your QuickBooks as an administrator ·Open Company file & Update QuickBooks again
QuickBooks Error 15243 When Trying to Export to Excel
When QuickBooks user is trying to export workbook or worksheet to excel. He comes across QuickBooks error 15243. The reason for this problem can be the payroll subscription. To resolve this error go to Quickbooks Payroll account maintenance page to re-validate the payroll subscription. Resolve QuickBooks Error 15243 in QuickBooks Payroll ·Open QuickBooks ·Go to the Employees option ·Choose My Payroll Service ·Select Manage Service key ·Click on the Edit option ·Verify your Payroll Service key ·Choose the Next option & remove the check for Open Payroll setup- I want to start right now ·Select the finish option ·After the verification, Go to Employees ·Select Get Payroll Updates ·Download Latest Payroll Update for QuickBooks Desktop & Update Contact QuickBooks Support to Repair QuickBooks Error 15243 If above-mentioned troubleshooting steps for QuickBooks error 15243 doesn't help. Get in touch with QuickBooks support team by dialing +1800-316-0126. A certified team of professionals is available around the clock to help you resolve errors like QuickBooks error 15243. Common Errors like QuickBooks Error 15243 ·QuickBooks Error 15271 ·QuickBooks Error 15215 ·QuickBooks Error 15101 ·QuickBooks Error 15214 ·QuickBooks Error 15203 ·QuickBooks Error 15222 ·QuickBooks Error 15262 ·QuickBooks Error 15102 ·QuickBooks Error 15106
4/4/2023 7:35:27 AM • Intuit Computers... • Answered on Apr 04, 2023
Intuit QuickBooks® Pro 2006 Full Version for PC (5 User/s) Logo
30 questions posted
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intuit Computers & Internet
Most Popular Question
problem loading quickbooks
  • Computers & Internet
