20 Most Recent Vitamix Vita-Mix Blending Station Advance Vm0115e On-Counter Questions & Answers
My blender goes on and off
I think your best bet with a machine like yours is to contact customer service. Check here: Contact Us Customer Service Vitamix
3/16/2015 1:27:10 AM • Vitamix Vita-Mix... • Answered on Mar 16, 2015
2answers
Vitamix TQO VM0145 The Quiet One blender with a 3Hp motor.
You can typically find replacement carbon brushes for Vitamix blenders at appliance repair shops, online retailers, or directly from Vitamix. Ensure you get the correct model-specific brushes for the VM0145 blender with a 3Hp motor. Double-check the compatibility before purchasing to ensure a proper fit.
3/12/2024 10:28:05 PM • Vitamix Blenders • Answered on Mar 12, 2024
Vitamix blender show SHUT DOWN
Talk to manufacturer they should be able to help.
7/17/2019 1:49:10 AM • Vitamix Blenders • Answered on Jul 17, 2019
Blender blades do not turn when under load, but run smoothly when empty container It is a Vitamix 6300 model
Check the black driving clutch on the top of the motor that engages with the other clutch half on the base of the blender jug. The fault should be there, normally it will be the motor part.
2/3/2019 7:13:04 PM • Vitamix Blenders • Answered on Feb 03, 2019
Vitamix blender recalls.
If you ask which Best Vitamix model is the finest this year, certainly I would recommend going through this guide to know about which Best Vitamix blender are actually market leaders. More to follow ... 10 Best Vitamix Blender, see Reviews every single Vitamix Vitamix 5200, Vitamix 7500, Vitamix 5300, Vitamix 750, Vitamix 5000, Vitamix 6300 Vitamix 6500, Vitamix 780, Vitamix E310, Vitamix S55, Vitamix Professional Series 750, Read more Vitamix Vs Other Brend Comparison Blendtec vs Vitamix, Vitamix vs Ninja, Vitamix vs Nutribullet. Also See Comparison Vitamix 5200 vs 5300, Vitamix 5300 vs 7500, Vitamix 5200 vs 7500, Vitamix 7500 vs 750, Vitamix 6500 vs 7500, Vitamix 5300 vs 6500, If you want to Read Best Blender Reviews you can visit The Electric Blender Website. osyer-1om0k1p5mbf135xbpkvgr4rm-1-0.jpg
8/26/2018 11:43:32 PM • Vitamix Blenders • Answered on Aug 26, 2018
2answers
My 6 months old vitamix 750 professional series heritage collection suddenly stops while running
If you ask which Best Vitamix model is the finest this year, certainly I would recommend going through this guide to know about which Best Vitamix blender are actually market leaders. More to follow ... 10 Best Vitamix Blender , see Reviews every single Vitamix Vitamix 5200 , Vitamix 7500 , Vitamix 5300 , Vitamix 750 , Vitamix 5000 , Vitamix 6300 Vitamix 6500 , Vitamix 780 , Vitamix E310 , Vitamix S55 , Vitamix Professional Series 750 , Read more Vitamix Vs Other Brend Comparison Blendtec vs Vitamix , Vitamix vs Ninja , Vitamix vs Nutribullet . Also See Comparison Vitamix 5200 vs 5300 , Vitamix 5300 vs 7500 , Vitamix 5200 vs 7500 , Vitamix 7500 vs 750 , Vitamix 6500 vs 7500 , Vitamix 5300 vs 6500 , If you want to Read Best Blender Reviews you can visit The Electric Blender Website.
8/26/2018 11:41:43 PM • Vitamix Blenders • Answered on Aug 26, 2018
2answers
I'm looking for the rubber gasket for the lid on a very old Vitamix 4000. Anyone know where I can find that?
What has worked very well for me in the past in similar situations (not with kitchen appliances but any older item needing a part) is find people selling the item or parts for the item on eBay, and then messaging them asking if they have a source for whatever it is I am looking for. Almost always this leads to what I need, whether it is for a camera or an old watch or a vintage computer or whatever. Messaging through eBay is easy, fast, and free. Simply type Vitamix 4000 in the Search box, and get the listings displayed, and then click on Contact Seller. eBay will send the message, and notify you when there is a reply.
8/26/2018 11:40:24 PM • Vitamix Blenders • Answered on Aug 26, 2018
2answers
Vitamix variable speed not smooth
Some models had a weakness with the variable resistance in the rotary switch but your description sounds more like the main PCB or even the motor both of which are very expensive parts to replace.
6/15/2018 6:22:42 PM • Vitamix Blenders • Answered on Jun 15, 2018
How to replace the blade assembly on my Vitamix commercial 4000 (stainless steel pitcher) I have the blade assembly but it's more complicated to replace than I thought. HELP.
there is a wrench (by Vitamix) for under $10. you can get it from amazon. it makes the job of removing a blade assembly much easier.
1/30/2018 3:54:45 AM • Vitamix Blenders • Answered on Jan 30, 2018
2answers
Our Vitamix MP is not turning on. No lights on
not sure if this link will help you out but have a look. Vitamix MP is not turning Google Search
10/30/2017 6:43:00 PM • Vitamix Blenders • Answered on Oct 30, 2017
I have a vitamix 5000 unit. Blade assy makes noice ; is loose. Where can I buy the set of bearings for the blade assembly?
You will need to source them from a bearing supply company as Vitamix only supply the bearings as a complete unit with the blade assembled. Once you have the bearings out take the sample with you to the bearing supply company for correct identification.
6/28/2017 5:07:05 AM • Vitamix Blenders • Answered on Jun 28, 2017
A friend lent me her
Sounds like you have wrecked something, you just place the beaker on the motor base, no turning required.
6/2/2017 6:03:16 PM • Vitamix Blenders • Answered on Jun 02, 2017
Vitamix 5000 vm0103. When set to Variable, it does not run at all. Works fine on high. Is there a way to determine whether it's the pentionmeter or controlboard/circuitry by using an ohm meter?
Put your meter across the 2 disconnected potentiometer wires and turn the knob and see if you get the sort of variation you expect to see. The pots do give a little bit of trouble and aren't worth very much, I'd be inclined to throw one in anyway, the very last thing you want it to be is the PCB, they are not cheap.
4/2/2017 7:48:57 PM • Vitamix Blenders • Answered on Apr 02, 2017
VITAMIX 5000 I CAN'T PUT ON MY DRIVE SOCKET CAUSE THERE'S NO WRENCH WHOLE TO DO IT.I NEED HELP
The wrench hole is hidden firstly by the large rubber part that holds the beaker and secondly by a blob of clear silicone that covers the hole for your allen key
12/5/2016 4:32:37 AM • Vitamix Blenders • Answered on Dec 05, 2016
Where can i find Vitamix drink machines in CA, USA?
Lollicupstore from you will get vitamix drink machines in CA,USA. Visit - www.lollicupstore.com
6/20/2016 11:48:28 AM • Vitamix Blenders • Answered on Jun 20, 2016
Each time we use our Vitamix 750 to make soup we get a metallic flavour that is really unpleasant. The only time I haven't had it is when making smoothies. Has anyone any idea what's causing this?
No because there is very little metal in contact with the food other than the stainless steel blade and the stainless fitting below it neither of which should be leaching anything into the food. Have a close look at the blade and the fitting under it for any signs of corrosion. You should write (not an email) to the Company about this issue and maybe they have some explanation because these are expensive machines.
1/4/2016 2:10:32 PM • Vitamix Blenders • Answered on Jan 04, 2016
Where can I get a manual for the said Vitamix?
Go here to download it as a PDf file. The 5200 is what I think is most similar to yours. https://www.vitamix.com/Owners-Resources/Product-Support/Owners-Manuals
6/18/2015 9:42:48 AM • Vitamix Blenders • Answered on Jun 18, 2015
2answers
Replace ball bearing
Part of the blade assembly or drive socket assembly?... check here: Amazon com vitamix wrench assembly Home Kitchen
3/20/2015 6:24:14 AM • Vitamix Blenders • Answered on Mar 20, 2015
Vitamix container ensambly
What do you need to know? container leaking? Not spinning right? Just change the assembly... check here: Amazon com vitamix wrench assembly Home Kitchen
3/16/2015 1:57:56 AM • Vitamix Blenders • Answered on Mar 16, 2015
Vitamix Vita-Mix Blending Station Advance Vm0115e On-Counter Logo
1 questions posted
Top Vitamix Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
View Most Popular
Vitamix Blenders
  • Vitamix Blenders
Most Popular Question
blender goes off
  • Blenders
