20 Most Recent Wareforce CG Underbar Glass Washer 208/230V Questions & Answers
Measure the temperature of the incoming water from your water source. Adjust water source temp to around 130 degrees, or what is required by data plate.
http://www.webstaurantstore.com/documents/pdf/wareforce_cg_service_manual.pdf
Wareforce CG... | Answered on Mar 23, 2015
You need to ensure the incoming water temperature matches the requirements on the data plate, normally around 130 degrees.
Check you data plate. The inlet temperature must match the machine requirements, which means that your incoming water is too hot and the water heater temperature needs to be turned down. Here is a link to a installation/service manual. http://www.webstaurantstore.com/documents/pdf/wareforce_cg_service_manual.pdf
When the noise occurs when there is no hot water being used, it's likely there is a vacuum that's siphoning water away from the unit and causing loud noise and vibration. ... Another common problem that can create noise in tankless water heaters is a dirty flow sensor which controls how much gas is sent to the unit.
https://www.youtube.com/watch?v=Fsb8Wx9PRvY
Water Heaters | Answered on Jun 24, 2020
NO HOT WATER
  1. If the tester indicates there is power to the terminals and the water in the geyser is cold, then the element is faulty. ( ...
  2. If the tester indicates there is no power to the terminals and the water is cold, then the thermostat is faulty.
https://www.youtube.com/watch?v=qCXmyhEY_k4
Water Heaters | Answered on May 06, 2020
check and tighten covers thats the only metal to metal contact thats your answer for a water heater --as for your heater the element has electrical current going thru it to make heat which will cause vibration and or a hum which is normal in future post your question in the correct category and add make and model so you can get a correct answer
Water Heaters | Answered on Apr 21, 2020
Maybe. Knowing what it is that is generating error code E34 would be good start. Need manufacturer and model number.
Water Heaters | Answered on Mar 02, 2020
depends on the RV & the heater. I have seen some heaters that work on both options.
Water Heaters | Answered on Jan 11, 2020
DOWNLOAD LINK
http://www.dl4all.com/aka/tag/osaka+gas+fan+heater+user+manual.html
OR
http://www.osakagas.co.jp/indexe.html
Water Heaters | Answered on Jan 10, 2020
Check the power? If you have power, the thermostat or element have failed
Water Heaters | Answered on Dec 21, 2019
untitled-undefined-undefined-0.png at the upper part of the heating element.. press that to reset.
Water Heaters | Answered on Dec 05, 2019
CONTACT OSAKA DEALER WE DO NOT RECOMMEND DIY FIXING THINGS THAT CAN GO BOOM IN YOUR FACE
Water Heaters | Answered on Dec 03, 2019
Hi Marty-
I found this link regarding your Paloma Tankless Water Heaters. There is a section on Troubleshooting FAQs. If you need additional technical support, there is a 1-866 number to call at the bottom of the link.
http://besttanklesswater.com/owners/homeowner+trouble.html
Hope this helps.
Water Heaters | Answered on Nov 27, 2019
Wareforce CG Underbar Glass Washer 208/230V Logo
4 questions posted
Top Wareforce Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Wareforce Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Wareforce Water Heaters
Most Popular Question
hot water gets 200 degrees breaks
  • Water Heaters
