20 Most Recent
Microsoft Windows XP Home Edition with Service Pack 2b for PC Questions & Answers
Packard bell
Packard Bell computers are realy too old to be running xp. Consider buying a new or used PC
5/24/2014 4:23:07 AM •
Microsoft...
Answered
on May 24, 2014
Windows Xp os service pack 2 CD KEY ?
If you have lost the CD Key Call up the Microsoft call center no, you may have to produce the bill copy.
Or else from the installed system using third party utility you can find the CD-Key installed on your system.
9/11/2010 2:16:36 PM •
Microsoft...
Answered
on Sep 11, 2010
Is there a fairly small download file for Service pack 2 for XP
First of all perform a speed check on your internet speed. I recommend speedtest.net for that.
If your speed is less than 2mbps then the file could take a while to download.
Try clicking on the links that i will provide bellow, use them one at a time and see if the download estimation changes.
http://www.softwarepatch.com/windows/xpsp2.html
http://www.soft32.com/Download/Free/Windows_XP_Service_Pack_2/4-992-1.html
http://www.topshareware.com/Windows-XP-SP2-download-17215.htm
http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en
Good luck and regards.
2/1/2010 4:18:36 AM •
Microsoft...
Answered
on Feb 01, 2010
Im having trouble installing winows service pack3
no u dont have to do it.
see if ure xp is genuine that is registered and sp3 is not this problem occurs. another reason is ure installation source may be damaged. u can try either to copy the sp3 contens to ur hard drive and try instaling from there.
12/9/2009 2:57:21 AM •
Microsoft...
Answered
on Dec 09, 2009
Pogo.ui2.awt.e@61ec49
try updating your java.
look at control panel - java click on the update tab and then click on update now. let it update then reboot and try your game.
If you can't find the java under control panel then you may have to instal java from Sun.
http://www.java.com/en/download/index.jsp
Download and run to install. Check for updates and reboot then try your game.
After all that it if it hasn't fixed it, it can just be a java programming error.
If the game is populaur these usually are fixed very fast. If you keep trying every few days it should get the updated file and your game will work again.
8/21/2009 10:56:07 PM •
Microsoft...
Answered
on Aug 21, 2009
Shucks Guys, I've been on before when my cd.dvd
No that should not be and it sounds like the drive may be bad. Try a paperclip, straighten it out, there should be a little hole on the drive on both of my drives it is just below the door, one drive it is on the left, the other is on the right. insert the paper clip in the hole and push in until the drive opens. You can do this while the computer is on. If the drawer opens and the light is still lit, my vote would be the drive is bad. If the light goes out, remove the paper clip and close the door and see if the light comes back on, if so, again I would vote the drive is bad.
8/19/2009 3:46:40 AM •
Microsoft...
Answered
on Aug 19, 2009
How to connect wifi with acer laptop
Any wireless router will work. You just have to find the router’s
signal on your computer (and sign in to the network potentially).
Your
laptop should have a built in wireless card. If it doesn’t, you won’t
be able to wirelessly use the internet until you do.
I’m assuming you are using Windows.
Click Start at the bottom of the
screen, the open your Control Panel. Select the category Network and
Internet Connections.
There should be a wireless network setup wizard
in there, and will help guide you through the process of setting
everything up.
If i am helpful please rate me.
Thank you.
Yboyandrei
8/19/2009 1:06:25 AM •
Microsoft...
Answered
on Aug 19, 2009
