20 Most Recent
Broderbund TunePlus for Apple iPod Full Version for PC (0705381103318) Questions & Answers
My tuneplus is not recognizing
you'll need to have latest version
2011.01.19.0the problem with the outdated version is that it was incompatible with the updated iTunes. and so anyone with iTunes 8 and higher won't be able to use Tuneplus. luckily, Broderbund/Mediashop managed to fix this. Though it seems the updated version isn't available through normal means of "Tools" then "Check for updates". so here's what you do, uninstall your current version of Tuneplus. then download and install this updated
patch.
Dont have internet on my computer im at the
here's the patch that you're looking for,
here. as for getting it to your computer without internet access and only using the library's computer, you would need someplace to save the program to. such as a flash drive or a disc or something for you to save the file to. that's about all i can think about for your options without an internet access.
I need my TunePlus 3.0
if your version isn't
2011.01.19.0, uninstall your outdated version of Tuneplus. then download
this, a updated patch version and install this instead.
according to
this. you'll need a "clean install".
Just bought Mediashop TunePlus 3.0
the latest patch is
2011.01.19.0
if updating normally doesn't get you this version, then uninstall it.
once uninstalled, install this, this is the updated patch version that should work. let me know if this helps you out.
I just install tunepluse in my computer,and i try
When you launch the TunePlus Application the first window you see should say version 2010.05.04.0
If it does not you will need to preform an update by clicking on the Tools menu inside of the program and select the option for Check For Updates.
Tunesplus 3.0 is not recognizing
update it by going to Tools then "Check for Updates"
once updated it, the version it says when opening tuneplus should say "Version
2011.01.19.0". if it doesn't have this version and it shows an older version. then uninstall it.
once uninstalled, download and install
this. this should solve your problem.
Hi, I downloaded the updates
1st, uninstall and your version again and see if it updates to version 2011.01.19.0
2nd, if updating it normally doesn't update to version 2011.01.19.0 then uninstall and download and install this
patch for it. Then see if this update works for you.
