20 Most Recent Jet Tech Systems F-14 - Multi-Purpose Ware Washer, Compact Counter " Questions & Answers
a plug can be warm. if it is hot to the touch, stop using it and have the machine checked and the receptacle check by a qualified technician.
Jet Tech Systems... | Answered on Sep 02, 2014
for models equipped with a drain pump;
verify that the pump is not clogged. if it hums during the fill cycle or rinse cycle then something is lodged inside. If it doesn't then it needs to be replaced.
for models without the drain pump;
something is interfering with the water flow. when the stand pipe is removed, the tank should empty in about one minute.
Most Jet-Tech dishwashers has one adjustable rinse thermostat and one fixed wash thermostat. The wash thermostat can be substituted with an adjustable thermostat. Location depends on the model. F-18 are located on top. F-22 are located under next to the wash tank. Search by part number or description
Jet Tech Systems... | Answered on Jul 15, 2014
On the F-14, the booster thermostat must be satisfied. The rinse thermostat must work properly and or the rinse heater. follow the diagram. This kind of troubleshooting is done by qualified technician. Remember to unplug the unit before opening the panels. It could be just a burnt wire on the rinse booster heater connection.
The detergent system on the Jet-Tech machine are all very similar. Near the solenoid valve under the machine, beside the drain connection, there are two wires, one red and one blue. Those wire will run the detergent pump when the machine calls for water. Two tube are attached to the pump. when looking at the pump from the front or clear plastic can be seen, the tube on the left (arrow going up) is connected to the container with the detergent. the tube on the right (arrow down) is connected to the back of the unit to inject the detergent into the tank. Some precaution should be taken to assure that the connections are tight and not leaking. if the tube shows signs of crystals inside, it should be replaced as the detergent as crystallized within. Search by part number or description
If the machine will fill on its own when it is empty then the rinse cam on the timer is defective
Jet Tech Systems... | Answered on Dec 29, 2013
No idea as i would either make my own or go to general store in alicante and ask the nice man if he has anything that would do the job if the original parts were not available
Jet Tech Systems... | Answered on Dec 25, 2011
www.jet-tech.com/products/F-18DP/f18_tech_manual.pdf
Copy and paste that link into your internet address bar or type it in.
That is your manual
Jet Tech Systems... | Answered on Sep 22, 2010
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jet Tech Systems... | Answered on Sep 01, 2010
If this is a common problem then ring the manufacturer, if not you will need to have it replaced.
Jet Tech Systems... | Answered on Aug 03, 2010
There are two screws that hold the plate in. Because they are recessed, you may not think they are the right screws. Look at this video for a step by step.
https://www.youtube.com/watch?v=Co8iNquHOLc
Dishwashers | Answered on May 25, 2020
To access the dishwasher filter, remove your lower dish rack to expose the bottom of your dishwasher. You can find the filter in a back corner of the tub bottom, or around the base of the bottom spray arm. Some dishwashers have a triple filter system with two parts: an upper filter assembly and a lower filter.
https://www.maytag.com/blog/kitchen/how-to-clean-dishwasher-filter.html
Dishwashers | Answered on May 20, 2020
Check the drain tube routing to the drain pipe. It should be positioned at some point higher than the entry location to prevent water running back to the dishwasher. Some dish washer detergents can plug the drain causing the back flow.
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Dishwashers | Answered on May 18, 2020
mine is doing the same what can it be
Dishwashers | Answered on May 16, 2020
Jet Tech Systems F-14 - Multi-Purpose Ware Washer, Compact Counter " Logo
1 questions posted
Top Jet Tech Systems Dishwashers Experts
Colin Stickland
Colin Stickland
ray gallant
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Jet Tech Systems Dishwashers
Most Popular Question
part number f 14 dishwasher timer
  • Dishwashers
