20 Most Recent J4constructioncom Black & Decker 14.4V Cordless Dustbuster Cyclonic Handvac LB152964 Questions & Answers
Fill container?
Vacuums | Answered on May 24, 2020
We love mystery appliances!
The fill / float ball is stuck at the top because your didn't clean it properly the last time you used it :>)
Vacuums | Answered on May 20, 2020
Hello Sheila
Pull the trigger and tape it. Put it in the sink or leave outside until the pressure comes down. Then tip it upside down, put the head unit between your knees wrapped in a towel, put rubber gloves on for grip and turn the base with your hands. You will get more leverage from the base.
Or ask a neighbour.
Vacuums | Answered on May 19, 2020
If you email me I will scan the manual, and email it to you.
[email protected]
https://www.youtube.com/watch?v=bfoarHAGLw8
Vacuums | Answered on May 17, 2020
This could be because the power voltage is either too low or high. Check voltage compatibility... Or because there is a blockage.
Vacuums | Answered on May 15, 2020
To generate strong suction, the motor has to turn at a good speed.If its a bag vacuum change bag with new one when a great deal of debris builds up in the vacuum bag, the air faces greater resistance on its way out.
Vacuums | Answered on May 14, 2020
To turn the brushbar OFF for bare or delicate flooring, rugs, and carpets, put the machine in the cleaning position, and press the red button. Press it again to restart brushbar. tip Ensure the stabilizer clicks into place before vacuuming.
https://images-eu.ssl-images-amazon.com/images/I/B1wH2T5dHDS.pdf
Vacuums | Answered on May 11, 2020
Check power, replace fuse.
Vacuums | Answered on May 10, 2020
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Vacuums | Answered on May 09, 2020
reverse it
Vacuums | Answered on May 02, 2020
www.hard-wood-floor-cleaners.com
and select the best chemicals and use for your hardwood polish laminate flooring.
God bless you
Vacuums | Answered on Apr 29, 2020
http://www.technofire.com.pk/product/fire-hose-reel-manual-automatic-swinging-types/
Vacuums | Answered on Apr 25, 2020
need to test switch or wiring for short or failure
Vacuums | Answered on Apr 24, 2020
YOU NEED TO CLEAN THE HAIR YOURS AND ANY PET YOU MIGHT HAVE OFF AFTER EVERY USE MY COUSIN HAS BLONDE HAIR AND HER VACUMN BRUSH HAD GOTTEN SO MUCH ON THE SHAFT THAT IT WAS LIKE A GLUE LOCKED THE BRUSH SOLIDLY IN PLACE .I GOT IT OFF AND OUT WITH A DENTAL PICK AND IT WORKS AS GOOD AS EVER NOW .
Vacuums | Answered on Apr 22, 2020
THERE IS NONE ON THE UNIT
Vacuums | Answered on Apr 18, 2020
J4constructioncom Black & Decker 14.4V Cordless Dustbuster Cyclonic Handvac LB152964 Logo
1 questions posted
Top J4constructioncom Vacuums Experts
Marvin
Marvin
JoeVacs
Thatvacguy.com
Are you a J4constructioncom Vacuum Expert? Answer questions, earn points and help others
View Most Popular
  • J4constructioncom Vacuums
Most Popular Question
red button base hoover
  • Vacuums
