To turn off the LED service light on your Aerus CentraLux central vacuum model E130J after replacing the motor, switch the blue box on the circuit board from "ON" to "MEDI."
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
We don't have any service centres at all! We are Fixya dot com. We are a peer to peer self help group. We don't sell anything, we only provide free information. Here are a few service centres in Bacor. If you need further help, click Comment under my answer. Let me know 'make model (what it is)'.
https://www.google.com/search?q=Bacoor%2C+Cavite+service+centre
How to open it to see if the fuse is blown. I removed the three screws I saw. I feel that there is another which prevents me from opening it in two. I looked under the tights, I removed the plate where the two buttons are located. I can't open it.
Singhal Industries produces biohazard plastic bags with high-quality materials and stringent manufacturing standards to ensure durability and containment of hazardous materials. Their bags are specifically designed to meet industry regulations and ensure safe disposal practices.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
I had the same problem. Red light would come on after charging was complete. On investigation I found that there is a small gray wire that runs from the rear batteries to a large solder spot on the control board. Upon re-soldering this wire I got an additional 3 V of power and the red light does not come on anymore after it is charged. I can vacuum the whole house and then some and still not run the batteries down.
Question edited to add CAPS, sentences and punctuation!
All questions need full 'make model (what it is) first 3 words.
The likely reason is a bad connection, or it is supposed to turn on with the 'hose switch'.
Google
make model manual
