20 Most Recent Broan-NuTone WS330 Kitchen Hood Questions & Answers
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Broan-NuTone... | Answered on Feb 23, 2014
Home Depot carried these filters.
Broan-NuTone... | Answered on Jan 10, 2011
It be just the bulb that needs to be re new
Broan-NuTone... | Answered on Jan 13, 2019
theres a round clip you have to pry off (its silver but first you remove the the cotter pin looking clip that just slides out)..took me a few to figure it out but its a pain to remove ..use a small flat screwdriver and you will get it off eventually..then when reinstalling you have to press it in while lifting the clip with again a small flat screwdriver.
Broan-NuTone... | Answered on May 25, 2018
is it on sleep mode...then it should switch off after sometime...try it
Broan-NuTone... | Answered on Feb 20, 2017
You may need a selector, and/or relay replacement.
Broan-NuTone... | Answered on Jul 12, 2015
You need to disassemble it to repair it, if you are not comfortable check into either a service person or replacing it.
Broan-NuTone... | Answered on Nov 27, 2014
Depends what is wrong.To call a repair man will cost a service call before he starts. Check all your wiring and see if there is a short. See what you can do before you call a repairman.
Broan-NuTone... | Answered on Nov 05, 2014
I just replace the whole thing if it has attic access. Have an electrician do it if you are not confident of your skill. Having the light work is not very helpful if the unit is shot. Clean and lubricate the fan shaft on your new one once a year and it will last a long time. You may be able to swap out just the fan if unplugs and it is not riveted in but you will have about the same time and money into it as replacement.
Broan-NuTone... | Answered on Oct 22, 2014
are you sure its water...does it have oil collector along filter...
or check for leakage from something from upper floor may be you have washroom or plumbing leakage
Broan-NuTone... | Answered on Aug 14, 2014
I dont think they have fuse ...you will have to disconnect from your switch panel
Broan-NuTone WS330 Kitchen Hood Logo
7 questions posted
Top Broan-NuTone Kitchen Ranges Experts
Marvin
Marvin
Paul Bade
Fahr Quad
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Broan-NuTone Kitchen Ranges
Most Popular Question
ws3 broan allure range hood premier 36
  • Kitchen Ranges
