20 Most Recent CyberPower CPS1200AVR (CYPCPS1200AVR) UPS System Questions & Answers
My Cyberpower 425VA does not keep the power on my computer after a power surge
replace batteries
6/18/2015 6:19:16 AM • CyberPower... • Answered on Jun 18, 2015
We get frequent power surges
The power overload warning should only come on if you have too much of a load plugged into the UPS. You may be close enough to the edge of the limit so the disturbance from a surge can be enough to trip the overload detector.
Your UPS is rated for 1200 Volt-Amps, so it can drive a maximum of 10 Amps at 120 Volts. Every piece of equipment should have a label with the maximum Amps or Watts on it. Add up the Amps used by the equipment plugged into the UPS/AVR sockets to make sure the total is less than 10 Amps. If the equipment label rates power requirement in Watts, divide that number by 120 Volts to get the amperage. One thing to read carefully is the label on the computer power supply. It is commonly rated in output watts, but that is not the number to use for this calculation. Since it is not 100% efficient, you need to look for the input Amps number.
If you are too close to the limit, move the printer or monitor to a surge-only outlet or consider replacing the monitor with a more energy-efficient unit. If your load total is less than 9.5 Amps, the UPS may have a defect in the power overload detection or internal voltage regulation circuits.
7/15/2014 4:40:24 PM • CyberPower... • Answered on Jul 15, 2014
Why does my cyberpower ups 1350avr show constant overload with nothing plugged in.
Please discard. Probably a short circuit in the inverter!
1/3/2022 7:56:34 PM • CyberPower... • Answered on Jan 03, 2022
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
10/16/2017 2:29:54 PM • CyberPower... • Answered on Oct 16, 2017
0answers
When there is a power surge the (power quickly off then back on), the unit doesn't provide battery power (connected items turn off), and the unit starts to beep.
just unplug the UPS and check for how long it runs on batteries, if time is short just replace the batteries. if you are using a line interactive UPS you may have to replace it by an online UPS
6/18/2015 6:12:13 AM • CyberPower... • Answered on Jun 18, 2015
0answers
Constant buzz
Be the first to answer 5/28/2014 3:33:42 AM • CyberPower... • Posted on May 28, 2014Be the first to answer
300 watt manual
Your not asking the right question. The answer is dependent upon how long you want the backup to work. Does a battery fit in the unit or is it alone? If you were to connect a car battery to the unit it would run for many hours, say a motorcycle battery would run maybe an hour. It is all about the time you want for run time.
3/30/2014 10:34:59 AM • CyberPower... • Answered on Mar 30, 2014
Bluetooth & Wireless switch
want rid of match.com popups
2/15/2014 3:34:36 PM • CyberPower... • Answered on Feb 15, 2014
0answers
0answers
0answers
Stop beeping
Be the first to answer 1/31/2014 8:05:22 PM • CyberPower... • Posted on Jan 31, 2014Be the first to answer
Shutting off
What is the UPS displaying prior to shutting down? How old is the UPS? Did you change the batteries? Need as much info as you can give to help you.
1/30/2014 7:26:27 PM • CyberPower... • Answered on Jan 30, 2014
CyberPower CPS1200AVR (CYPCPS1200AVR) UPS System Logo
2 questions posted
Top CyberPower Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • CyberPower Computers & Internet
Most Popular Question
cyberpower 425va not keep power computer
  • Computers & Internet
