20 Most Recent Humminbird Piranhamax 220 Fishfinder Questions & Answers
HOW TO HOOK UP THE power
Humminbird... | Answered on Aug 04, 2016
It ever well could be a transducer or a unit issue. I would contact customer service and see what they can work out for you.
Humminbird... | Answered on Feb 07, 2011
I would contact our customer service group and see if they can help you out. There number is 800-633-1468.
Humminbird... | Answered on Jan 03, 2011
There should be an in-line fusible link on the power supply wire and it should be checked for a blown fuse. If there is no fuse protecting the head unit, it may have received a voltage spike internally and caused internal circuit damage, requiring replacement. What can be done is remove the head display unit and wire it (with a fuse link) to battery posts and see if it powers up. If the unit does not come on, then the head unit will need to be replaced.
Humminbird... | Answered on Dec 04, 2010
here is the link to a website that you can download install manual. it is free. it will ask for a survey, you can skip it. click here to go there.
Humminbird... | Answered on Nov 05, 2009
In a pinch, probably. For long term, no. ther eason being that you cannot get a good enough connection on the jacketed cable to make the sounder work properly. That and the fact that there is alot of voltage running through the wire!
Best to replace it.
Mike
Humminbird... | Answered on Sep 27, 2009
If you are 'testing' the unit by holding the right button and pressing power, the pmax units really don’t work with the internal test. What you are seeing in the test is what th humminbird factory computer test used to test it. That is really not intended to be used outside of the plant. If it works fine in normal mode then I would say that the unit is fine.
Best of luck!
Mike
Hi!
If your 220 is in portable configuration (runs on 8 'AA' batteries) make sure that the batteries are 1.5 volts and not 1.2 or 1.3 volts. (1.2V times 8 batteries is only 9.6V)
Also check the battery compartment as we see leakage from some batteries which corrodes the connector plates that the batteries hook up to.
One more thing...check to see that the power cord is plugged into the unit with the notch in the plug pointing UP. The rubber plug housing on the sounder allows the cord to be plugged in backwards if it's forced a litlle bit.
Best of luck!
Mike
I found what you are looking for. Go to: http://www.humminbird.com/support/FAQ.aspx?faqid=72
You can download the operating manual.
Humminbird... | Answered on Nov 26, 2008
If its under warranty, send it back. They will say you grounded it or hit log. If not, buy a new one. You can't fix them.
Humminbird... | Answered on Feb 26, 2020
Humminbird Piranhamax 220 Fishfinder Logo
25 questions posted
Top Humminbird Boating Experts
Bill Eager
Mike
ray gallant
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
View Most Popular
Humminbird Boating
  • Humminbird Boating
Most Popular Question
unit will not start up
  • Boating
