20 Most Recent Humminbird 161 Gps Fish Finder Combo Questions & Answers
I don't have the same model but the same issue before the cable from the sonar was frade some and so it wasn't sending a good signal to the box so it just said loading I had to replace the sonar and then it worked fine
Humminbird 161... | Answered on Sep 23, 2013
It should work right out of the box. It may have trouble picking up satellites, especially if you are testing it inside your house. A lower-end unit like this isn't going to have as powerful an antenna as more expensive models, so be sure you are outside, with a clear path to outer space and it should work!
Hope this helps.
Humminbird 161... | Answered on Jan 21, 2011
The first thing you need to check is if you have sufficient power going to the fishfinder. Take a multimeter and measure the dc voltage going to the display when the unit is off and also on. If this is below 12 vdc this is your problem. You will need to check for loose connections and possibly replace your battery.
If the voltage is good then the problem lies within the display. Unfortunately, you would have to contact Humminbird directly to return the display for repair or purchase a new fishfinder.
Humminbird 161... | Answered on Jun 29, 2010
Hi!
here is a manula for your reference:
Humminbird 161
that should get you started :)
Best of luck
Mike
Humminbird 161... | Answered on Sep 26, 2009
You cant change time since is gps controlled. All you can do is to choose correct time zone For example NY should be GMT -5 hrs
Humminbird... | Answered on Sep 02, 2019
Change your transducer.
Humminbird... | Answered on Feb 13, 2018
Ask any 4 year old... they are geniuses when it comes to handheld electronics these days
Humminbird... | Answered on Nov 02, 2017
With this type of issue.. its the transducer mounting ...99% of the time!!
Humminbird... | Answered on Sep 25, 2017
Humminbird 161 Gps Fish Finder Combo Logo
Popular Tags
9 questions posted
Top Humminbird Boating Experts
Mike
ray gallant
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
View Most Popular
Humminbird Boating
  • Humminbird Boating
Most Popular Question
161 gps hummingbird isnt
  • Boating
