20 Most Recent Trademark Global Sealtite Food Bag Sealer Questions & Answers
Trademark Global... | Answered on Mar 01, 2013
That may be very hard to do without changing the dye color. The longer it is in there the worse it will be.
In order:
1) try tuff stuff foam cleaner you can buy at Wal mart
2) if that does not work - try mineral spirits to see if it comes out. Finish with Tuff Stuff to get residual mineral spirits out
3) if those 2 do not work - this is the last ditch effort - you will need a commercial solvent. May take the dye out and hurt the carpet fibers.
Good Luck!
Vacuums | Answered 3 days ago
Put a piece of clean fabric over the wax and use a warm iron on top of the fabric to melt the wax, rub and repeat if necessary
Request from the manufacturer/distributor
Vacuums | Answered on Dec 01, 2020
Vacuum cleaner hose can be bought off the roll in some repair establishments, usually those places that primarily service the needs of trade customers.
The trouble is, although a length of hose can be bought, it isn't helpful in every case as manufacturers these days tend to weld the end fittings to their hoses making it almost impossible to separate, forcing people to pay inflated prices for replacement hoses as a spare part from the vacuum cleaner manufacturer or an aftermarket supplier.
Vacuums | Answered on Nov 29, 2020
WITH NO WAY TO TEST WE CAN NOT GUESS
Vacuums | Answered on Nov 23, 2020
If you have mostly hard floors you can't go wrong with a Miele canister vacuum. They have many models out. I would suggest one with a 14" horse hair floor brush. they are german made and last for years. Don't buy a Dyson they are very harsh on hard floors and your carpet.
Vacuums | Answered on Nov 20, 2020
overuse no doubt so buy a new one :)
Vacuums | Answered on Nov 18, 2020
fixya does not source vacuum cleaner parts. Check with a repair shop.
Vacuums | Answered on Nov 10, 2020
May you explain more what happen? Did a cap get stuck in the hole? If so take a household vacuum and use the attachment tool to suck the cap out.
Need expert help?
https://www.6ya.com/mr.mike
Vacuums | Answered on Nov 05, 2020
Contact Genie directly to request the manual for model SV300Q.
Vacuums | Answered on Oct 29, 2020
Contact Chi directly to request the manual.
How to Repair a Hoover FloorMATE ' Hunker
www.hunker.com > ... > Other Home Appliances
Sep 7, 2018 - The Hoover FloorMate makes cleaning floors easy. ... The Hoover FloorMate takes over where traditional dry vacuum cleaners leave off. ... If water puddles behind your FloorMate, make sure the cleaning solution tank is in the ...
See questions and answers - Amazon.com: Customer ...
www.amazon.com > ask > questions > asin
Hoover FH40160PC FloorMate Deluxe Hard Floor Cleaner, Wet Dry Vacuum, Silver ... will drip from brushes and underside of the product after use and puddle.
Hoover FH40160PC FloorMate Deluxe Hard ... - Amazon.com
www.amazon.com > product-reviews
Hoover FH40160PC FloorMate Deluxe Hard Floor Cleaner, Wet Dry Vacuum, ... YOU AFTER PURCHASE AND LEAVES IT UP TO AMAZON TO DEAL WITH.
Vacuums | Answered on Oct 24, 2020
You would have to take your vacuum cleaner to a place that repairs and fixes vacuum cleaners in order to have the power cord to be replaced.
Vacuums | Answered on Oct 21, 2020
I know exactly what you are talking about, Craig please enlighten us as to which page in the manual will be the quick and easy fix to this problem. Since you are not understanding exactly what the problem is, you simply think the person asking can't read it didn't bother trying anything else. But since the problem is not a typical problem, they asked here, looking for someone who fully understands exactly what they are going through.
The problem is that there is no problem, what's actually happening is this. Normally Bissells steam cleaners really don't have all that much suction power and that means less air moving through the system even if there's higher pressure to do so, but some of their cleaners are sucking better which moves more sir through the system and inside the tank where that flapper cover piece is located, there's also the fill hole and the bladder laying in any which way it may be.
When the air is drawn into the tank, it can create some bursts of higher air movement in the tank as the nozzle moves along the carpet top. There may be times when you are pulling it back and stutter a bit which will allow more or less air in the nozzle which created a stronger flow through the tank and right there where the flap is located, there's very little room for the air to pass around that door without making it start to close due to that quick burst. Once it catches the flap in a gust it has no where else to go and brings the flap up due to the suction at that small sized opening.
so what's wrong with your cleaner is called engineering failure, the flap was not designed correctly and fails to operate normally. If the opening for the air was larger or the flap was made heavier or in a different more open area in the tank this would never be a problem. The only solution I have come up with that's an easy fix is to remove the flap. Of course the flaps intended purpose is to keep water from entering the motor. So removing it means you would have to be much more careful with how you move the cleaner around, turning it off before doing and tipping around it fast movements that would cause water to splash. But if you can't even use it like it is then who cares if you have a wall chance if damaging the motor.
Other option is to add some weight to the flap so it will not be as easy to get caught by the air movement at that point. This is only going to work if you take the time to experiment with exact weights and to where it's added. Since it is water adding iron based metals is out. I have figured the best way to be using a stick of the 2 part epoxy type "claylike" bars that you knead together and apply it across the top outside edge of the flap which will make the air pressure be higher to lift the door. I can't say his much will be needed, it depends on how much air is moving and it the weight is not too much that it interferes with the normal closing as the bladder empties and fills the outside where the arm pushes it up and closed. So that's where it needs testing. It may not work at all if the air is swirling around vigorously, a smoke test should really be done to see exactly what's going on with that area.
I have removed mine and it works better than any other bissell I have ever tested, although I think bissell makes the most problematic cleaners in the world and would never keep one to use for myself when I can use a hoover which will never have all these constant problems that every bissell model since the started with the tank that splits in half. Absolutely the worst cleaner ever made, it's no great loss if the motor goes out IMO if it makes you buy a hoover, then you're already going to be better off. You won't be wasting your time constantly trying to get the bissell to work, your carpet will get clean for the 1st time and you will be able to walk on your carpet after a few hours of drying since the hoover will extract 50% more water from your carpet to begin with. Especially after both cleaners are 5 years or more old, the hoover will continue to work like new for 10 or more years while you'll be lucky to get 3 years from a bissell and you'll be fighting it the entire time.
Vacuums | Answered on Oct 20, 2020
It has a blockage. The whining is the motor straining, and it get hot because the airflow is reduced. Take is all apart, right down to the motor if you can. Take pictures so you know how to put it back together. I moved your post from Televisions to the Vacuums category :>)
Did you know there is a recall on it due to FIRE HAZARD!
https://healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2020/73271r-eng.php
Further information
https://www.google.com/search?q=Rainbow+SRX&rlz=1C1QJDB_enCA643CA644
Vacuums | Answered on Oct 16, 2020
Trademark Global Sealtite Food Bag Sealer Logo
3 questions posted
Top Trademark Global Vacuums Experts
Marvin
Marvin
Are you a Trademark Global Vacuum Expert? Answer questions, earn points and help others
View Most Popular
  • Trademark Global Vacuums
Most Popular Question
sealtite
  • Vacuums
