20 Most Recent Raymarine Dsm30 Digital Sounder Module Questions & Answers
Sometimes lose depth reading ( dashed ) and
I have exactly the same problem. I have sent the unit for repair by Raymarine UK. I am waiting for their response. As soon as I have it I will posted. georges
11/19/2011 8:49:04 PM • Raymarine Dsm30... • Answered on Nov 19, 2011
0answers
2answers
Raymarine "DSM connection lost"
Murray,
Has the DSM and the E120 software been upgraded to the latest software: 4.12 for the DSM and 5.52 for the E120?
Try this first. You can download the software off Raymarine.com and burn each to a separate compact flash card.
I have seen many problems like you are experiencing solved with this simple change.
If this doesn't solve the problem, the DSM will have to go back to Raymarine for repair.
8/8/2010 12:33:31 AM • Raymarine Dsm30... • Answered on Aug 08, 2010
2answers
Picture freeze
It sounds like a software issue. If the depth still shows numbers and not dashes, that indicate that the DSM and trandsucer is working. Be sure that you have the most recent software for the E120 and for the DSM. You can find info about the current software and how to load it on Raymarine's website. It is important to perform a factory reset once the new software is loaded. If that doesnt solve your trouble, you will need to consult Raymarine's tech support dept.
1/22/2010 7:49:08 PM • Raymarine Dsm30... • Answered on Jan 22, 2010
Sounder picture on e 80 freezes 20 min. after power on.
your feeling is correct on this it is still probably software! but also be aware that the power in connections are very susceptible to vibration and strains and once cracked inside they get a mind of their own. If this is a come and go problem that won't resolve, reflow the solder joints inside the DSM.
1/15/2010 4:48:19 AM • Raymarine Dsm30... • Answered on Jan 15, 2010
How do I connect my garmin 741sx with my raymarine St 4000 with nmea 183
To connect your Garmin 741sx with your Raymarine ST 4000 using NMEA 183, you will need an NMEA 0183 interface cable to connect the two devices. Here are the steps to follow:
  1. Obtain an NMEA 0183 interface cable that has the correct connectors for your Garmin 741sx and Raymarine ST 4000.
  2. Connect one end of the NMEA 0183 interface cable to the NMEA output of your Garmin 741sx.
  3. Connect the other end of the NMEA 0183 interface cable to the NMEA input of your Raymarine ST 4000.
  4. Configure your Garmin 741sx to output NMEA 0183 data. Refer to your Garmin 741sx manual for instructions on how to configure NMEA output.
  5. Configure your Raymarine ST 4000 to receive NMEA 0183 data. Refer to your Raymarine ST 4000 manual for instructions on how to configure NMEA input.
  6. Once both devices are configured, the data from the Garmin 741sx should be transmitted to the Raymarine ST 4000 via the NMEA 0183 interface cable.
2/23/2023 5:01:41 PM • Raymarine... • Answered on Feb 23, 2023
Raymarine C70. Como cambiar la pantalha de modo diurnos a noturno ?? en el Raymarine C70.
Question edited for clarity.Question moved from Cars and Trucks to Raymarine.Adjusting the display lighting The display has two distinct color palettes, for day and night operation. You can alsomanually adjust the backlight level.Note: The display lighting is a local setting and will therefore only affect the individualdisplay on which you are working.Day/night operationTo select the day/night mode of operationhttps://www.manualslib.com/manual/138190/Raymarine-C-Series.html?page=30#manual
8/3/2022 6:36:50 PM • Raymarine... • Answered on Aug 03, 2022
I want to mount a sonar transducer for my raymarine dragonfly-4 on my 16 foot aluminum boat where do I mount it Thank you
on the transom outside of the boat silicone the bolt holes
10/29/2021 12:36:07 AM • Raymarine... • Answered on Oct 29, 2021
Raymarine c120 classic intermittent no data source
"Finally convinced him that **your** specs requiring the 4c cable at those lengths was correct" You know we are Fixya and not Raymarine? We just have a Raymarine category for handy filing of questions and answers. This question needs a factory service department technician on the phone. As a boat owner, who doesn't have radar, and reading your post carefully, I would suggest the connection at the top of the mast. It is far more hostile up there, and it has been up there a long time.
7/10/2021 9:20:46 PM • Raymarine... • Answered on Jul 10, 2021
Need Manual for Navico WP5000
get ie here -
http://hem.passagen.se/beg_stockholm/wheelpilot_manual-no_pic.html
8/3/2018 9:46:52 PM • Raymarine... • Answered on Aug 03, 2018
I have a Raymarine Axiom system on my boat. Can you help me.
Check with Raymarine. Model number would be of use. http://www.raymarine.com/view/?id=10125 Raymarine Manuals Documents
6/21/2018 12:27:41 PM • Raymarine... • Answered on Jun 21, 2018
Raymarine 4000 + autopilot. I immediately get an RG Fail message when I engage the autopilot on my Catalina 320 Sailboat.
I am not familiar with your particular model autopilot, but I do know that Raymarine autopilots can be fussy. All must have a compatible gps feeding it, of course. All must have a rudder angle indicator if your auto pilot connects to the wheel or rudder instead of directly to the tiller. I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
1/3/2018 10:37:57 PM • Raymarine... • Answered on Jan 03, 2018
How do I calibrate my raymarine st2000+ auto helm
Hi David. A little late, but the information you require can be found here: http://www.raymarine.com/view/?id=346 Hope it helps someone else out. -Steve Raymarine ST1000 ST2000 Tiller Pilots
12/31/2017 2:47:32 AM • Raymarine... • Answered on Dec 31, 2017
Raymarine Dsm30 Digital Sounder Module Logo
Popular Tags
9 questions posted
Top Raymarine Boating Experts
Colin Stickland
Colin Stickland
Mike
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
View Most Popular
Raymarine Boating
  • Raymarine Boating
Most Popular Question
raymarine dsm connection lost
  • Boating
