20 Most Recent
Reddy HEATER RH125T 125,000-BTU PROFESSIONAL SERIES PREMIUM PORTABLE KEROSENE FORCED AIR HEATER W/TH... Questions & Answers
I replaced all filters and the nozzel pump presure
I want you to inspect the fuel tank, you are looking for water that may have entered while in storage. Condensation builds from storing them and it can duplicate what you are saying here. What I did was to empty the fuel in a clean five gallon bucket and observe, fuel is lighter than water so it floats to the top water sinks to the bottom. If water is present please try to dry out the tank the best you can by soaking it up with a rag. You can siphon off the fuel just be careful not to get the water. If no water is present check to see how the igniter is positioned in conjunction to the angled spray of atomized fuel.You may have to bend it in a little closer to the fuel.
Reddy HEATER...
Answered
on Dec 28, 2010
Reddy heater has problem staying on
Check the foam filters located in the back, their is also a primary air adjustment slot in the back try adjusting that each time you fire it to see if you can get it to stay on.
Can you see the fuel oil coming out of the nossle? If
not clean it. If it has a cad cell that could be bad or dirty, you might have to bypass it to see if that is the
problem.
Reddy HEATER...
Answered
on Jan 15, 2010
I have reddy heater125t the flame lite
It sounds more like airflow and too high of a temp. The fan blades and return vent side must be very clean to keep this big guy pushing the btus out of the heater. A restriction of any kind could cause this overheating situation causing it the shut itself down. If you are confident that air is not the problem, make sure the nozzle that the kerosene comes out of is clean also.
Reddy HEATER...
Answered
on Jan 09, 2010
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Reddy HEATER...
Answered
on Dec 18, 2009
Will ignight but wont stay running keeps going
one thing to check is the air pressure,there is a low pressure gauge to do it with i no the 55,000 btu is 3.5lbs they are all different and if they are not right it will cause these problems,im having the same problem with mine i dont have a gauge but thats what i have found out,clean the fuel tip,i think the circuit board is bad on mine,if the board gets wet it will do the same thing i have found that out also ,good luck to all
Reddy HEATER...
Answered
on Dec 17, 2009
When i plug it up and turn the switch on the light
The i unit is a forced air Kerosene heater and if you are not experienced in the repair of this unit, I would really suggest having the unit serviced by a certified technician.
If when you plug in the unit and try to power up the unit, and as you say, " nothing happens ".
The unit has a forced air blower, a thermostat, and a ignore.
If any of the above are not working correctly, the unit will not start, as these are all safety backups.
You will need to check these units one at a time.
Please consider have this unit worked on by a cirtified technican.
I hope you have little expense with this repair.
Happy Holiday's
Please rate kindly
John
Reddy HEATER...
Answered
on Dec 06, 2009
RH125T won't fire
Not much to check. The element comes out and makes a square loop back to the ceramic portion. This element is extremely brittle and will break if touched or wiped off.
You can check the 2 wires with a voltage tester set on continuity. The needle should swap sides if the ignitor is intact. I don't ever remember an ignitor failing, except for breakage.
View this page. Be sure you get the correct ignitor. 2 different ones have been used on the RH125T.
http://www.reddyparts.com/125T%20ignitors.htm
Reddy HEATER...
Answered
on Mar 24, 2009
RH125T won't fire
If you blew compressed air into the combustion chamber from the nozzle end of the heater there is a good chance that you broke the ignitor. Check it.
Reddy HEATER...
Answered
on Dec 26, 2008
