20 Most Recent Xantrex Technology Heart Freedom 20 12 Inverter Questions & Answers
Our trace legend series 1
Is the inverter configured for correct type of batteries? Did inverter come with temperature sensor what should be connected to battery to prevent overheating? Are batteries in good condition, acid level, clean posts etc?
9/2/2019 9:14:51 PM • Xantrex... • Answered on Sep 02, 2019
One output leg is dead.
if there is no extraordinary load your breaker may just be worn out. Unless you know what your'e doing don't mess around in the box! Get a electrician.
1/15/2018 5:38:42 PM • Xantrex... • Answered on Jan 15, 2018
I have a freedom 20 with a link 2000 remote. The remote worked when I got the trailer except that the display was week and fadeed in and out, my son tryed to hook 8volt batteries up to system and caus
Call Tekris they are in Farmingdale NJ 1 888 438 5747 They are very professional reasonable and have helped me out a couple of times Highly recommended
11/16/2017 5:29:02 PM • Xantrex... • Answered on Nov 16, 2017
My Xantrex Technology Heart Freedom 25 will not charge. The unit turns on and begins to charge but the overheat light comes on within 2 seconds and shuts the charging function down. It turns on the e
  1. Call Tekris Located in Farmingdale NJ 7329384996 Great people to deal with Fair prices excellent service
11/2/2017 2:14:29 PM • Xantrex... • Answered on Nov 02, 2017
0answers
0answers
Lo batt blinks continously on Link 2000 monitor display
Am sorry but I have same problem and have tried manufacturer with no response,Jeremy
6/28/2014 12:43:07 AM • Xantrex... • Answered on Jun 28, 2014
Appears to not be charging
Anytime external AC is being applied, the unit passes that AC input through to the output, independent of inverter/charger status. If external AC power is available but the unit is not charging (i.e. the Charge light is lit, but the batteries are not charging up as they should), then there is likely a problem with the AC sensing circuit card inside the unit, with a 1/4 amp fuse and/or the AC transformer the most probably culprits. Without external AC, the inverter will function all the way down to 10V, but then will shut off, so as long as your batteries have not been totally depleted,the unit will still be able to produce 110 AC after a brief charge cycle, but it won't for long.
3/19/2014 7:42:00 PM • Xantrex... • Answered on Mar 19, 2014
Inverter will not shut down. I turn off the remote
depends on the serial # of your inverter.... the inverter switch on the machine should be turned off and controlled by your remote. If the switch is on at the machine, the remote won't control that part of it.
1/22/2014 7:42:11 PM • Xantrex... • Answered on Jan 22, 2014
Inverter is draining house batterys on rv
it is possible that you batteries are bad, if you have used it for over a year you will need to replace it with new ones
4/26/2013 10:51:13 PM • Xantrex... • Answered on Apr 26, 2013
2answers
Freedom 20 Inverter/Charger Overload will not reset.
When I switch my Freedom inverter on it shows E02 fault Low battery voltage. I have had the batteries tested and they are okay.
When I plug into the mains to charge batteries the Chrgeheart interphase shows charging light but nothing happens No current.
If anyone could advise I would greatly appreciate it. Thanks
Ian
3/28/2013 7:53:47 PM • Xantrex... • Answered on Mar 28, 2013
Xantrex Technology Heart Freedom 20 12 Inverter Logo
100 questions posted
Top Xantrex Technology Boating Experts
ray gallant
Dariusz Zalewski
Dariusz Zalewski
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
View Most Popular
  • Xantrex Technology Boating
Most Popular Question
heart interface freedom 20
  • Boating
