20 Most Recent Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12 Questions & Answers
I used Tekris when my inverter failed , Very professional ,reasonable and highly recommend them 18884835747 hope that HELPS
Xantrex... | Answered on Nov 16, 2017
Call Tekris 732 938 4996 Great people to work with Located in Farmingdale NJ. Fair price and excellent service
Xantrex... | Answered on Nov 02, 2017
I have the same problem but on an intermittent basis. The first time it happened the tech suggested resetting the default settings and it came on immediately. However the problem has been reoccuring from time to time and I now have no confidence in my one month old unit.
[email protected]
Xantrex... | Answered on Feb 22, 2011
Try http://www.xantrex or try just for asnwers at, justanswer.com/xantrex
good luck.
Xantrex... | Answered on Jan 30, 2011
I dont think there is a setup feature..
1.) ensure the inverter is getting power from the ac, use a multimeter to check this.
2.) check Fuse
3.) check its in the propper operating perimeter (voltage amps, etc)
Check the unit itself is getting power,..
Xantrex... | Answered on Nov 11, 2010
The following site gives you an idea. Please download the manual from there in pdf format.
http://www.xantrex.com/documents/Discontinued-Products/Freedom%20Jazz%201000%20-%201500%20-%202500.pdf
Xantrex... | Answered on Oct 25, 2010
Assuming it was working correctly at some time in the recent past (i.e. not a new installation and/or changed wiring), the "Invert" light is off on the panel and will not come on when you press the button, battery voltage is between 10V and 15V and you don't have a bad battery/cell that pulls the entire bank down the instant the charging voltage is removed, and the unit is well-ventilated and not in thermal overload, the problem is most likely an internal failure which will necessitate taking the unit to a factory authorized service center, since Xantrex does not sell parts or schematics to the general public.
Xantrex... | Answered on Sep 27, 2010
I have the same problem with my Freedom Marine 25. Assuming it worked previously and you have checked all the obvious things (generator/shore power breaker contacts, etc.), the Xantrex tech says it is likely a small 1/4 amp slow blow fuse on the AC sensing card inside the box, but that the AC transformer may have shorted to cause the fuse to blow. The internal arrangement may be different but remove the cover screws and locate the 2"x2" transformer on the AC sensing card for signs of arcing or charring. If you have a meter, check the transformer coils and if it reads significantly less than ~ 130 ohms, that is likely your problem, which will require taking the unit to an Xantrex authorized service center, since Xantrex does not provide parts or schematics to the general public.
Without more information, it could be a number of things. For starters, you might try disconnecting the ground wire to see if that makes any difference. The Xantrex Owner's/Installation Manual says specifically not to connect the inverter's negative *battery cable* to the vessel ground, but if the unit's housing and the negative cable share a common ground somewhere inside the unit, that would be the same thing. The T-105s are great batteries, but since they are 6V, make sure you rewired them correctly, i.e. a pair in series (12V) wired in parallel with the other pair for 450 AH total. Recheck all your battery connections and make sure you didn't blow the inline battery fuse in case you inadvertently made a momentary wrong connection during the new battery installation.
I have the same unit that the charging function just died on. If I can't fix it and have to buy a new one, you can have my comm board for free. Should know my status in ~ a week .
I am assuming that no fault lights are showing on the remote panel, but if they are, then those indicate a problem, e.g. overtemp, or AC overload. If the former, allow the unit to cool down and/or provide more ventilation, and if the latter, reduce the AC load by turning things off. The inverter must be in "standby" mode (green inverter light slowly flashing) for the inverter function to come on automatically when the incoming AC is shut off. Also, the battery bank voltage must be between 10V and 15V for a 12V system, the inline battery fuse must not be blown, and the unit's pop-up breaker (on the right front of the box) must not be tripped.
the charge fuse may have broken or the charger is bad
Very strange, intermittent problems like these can be a nightmare to diagnose. So even though the battery is full it is still kicking off on it's own? That tells me there is something internally failing as it should only turn off when the battery has completely drained, AND the power source has been cut... that's kind of the point of the battery... How old is this unit, do you think it's still under warranty? If so I would definitely claim it under warranty and get a replacement...
Xantrex... | Answered on Sep 22, 2010
No, not on your model.
Xantrex... | Answered on Aug 07, 2010
make sure your new inverter is made for 220 volt supply as that is what the red wire represents. its the other leg of a 220 circuit and should not be connected to your new inverter until you read the manual to see if it is designed for this and if so how to wire it in. it could cause you are the unit serious harm if you connect a 110 inverter to a 220 circuit. consult an rv repair shop or a good electrition if you cant find the needed info. it may actually be printed on the side of the inverter as well.
Xantrex... | Answered on May 29, 2010
Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12 Logo
Popular Tags
34 questions posted
Top Xantrex Technology Boating Experts
ray gallant
Dariusz Zalewski
Dariusz Zalewski
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
View Most Popular
  • Xantrex Technology Boating
Most Popular Question
when charging 2500
  • Boating
