20 Most Recent DCS WO-230 Stainless Steel Electric Double Oven Questions & Answers
RGV2-485GDN - DCS Fisher Paykel gas oven on range will not reach high temperature
Based on the information you provided, it sounds like you have already done a thorough job troubleshooting and attempting to resolve the issue with your DCS Fisher Paykel gas oven. If the oven is not reaching high temperatures even after you have replaced the igniter and dual gas valve, and swapped the circuit board from the working side, there are a few other things you can check:
  1. Check the oven thermostat: The thermostat is responsible for regulating the temperature in the oven. If it is not functioning properly, it may be preventing the oven from reaching high temperatures. You can test the thermostat with a multimeter to see if it is functioning correctly.
  2. Check the oven temperature sensor: The temperature sensor is located inside the oven and sends temperature readings to the control board. If it is not working properly, it can cause the oven to not heat up to the desired temperature. You can test the sensor with a multimeter to see if it is functioning correctly.
  3. Check for obstructions in the gas line: If there is a blockage or obstruction in the gas line, it can prevent the oven from getting enough gas to heat up to high temperatures. Check the gas line for any debris or blockages and clean them out if necessary.
  4. Check the regulator: The regulator is responsible for regulating the pressure of the gas going into the oven. If it is not functioning properly, it can prevent the oven from heating up to high temperatures. You can test the regulator with a gas pressure gauge to see if it is functioning correctly.
If none of these solutions solve the problem, it may be best to contact a qualified technician to further diagnose and repair the issue with your oven. They will have access to a service manual and specialized tools needed to diagnose and repair the oven.
2/26/2023 4:29:48 PM • DCS Ovens • Answered on Feb 26, 2023
Dcs wo-230ss double ovens shut off/dead after having both at 500 making pizzas
260°C or 500°F is hot enough to damage the electrics within the oven. Call an appliance repair service for a repair.
2/8/2023 7:58:53 AM • DCS Ovens • Answered on Feb 08, 2023
Dcs wall oven. Glass door cleaning
https://www.youtube.com/watch?v=N5tyw4cw0pM
1/2/2023 7:13:06 PM • DCS Ovens • Answered on Jan 02, 2023
HELLO , I HAVE A 30 INCH DCS OVEN SELF CLEANING DOOR WILL NOT UNLOCK AFTER 5 HOURS AND IT NEVER GOT HOT , WILL NOT OPEN AND ITS MAKING NOISE . ANY HELP PLEASE ?
Hi Steve, from what you're describing,it sounds like you've got a bad door lock motor. It should have 2 check switches on the assembly. If one or both of those switches are bad,the control will not read the lock as being engaged so it will not allow the cleaning cycle to start. To get the oven door open you need to pull the locking hook over to the right with a coat hanger. To access the lock assembly you have to get under the top. It's a pain in the rear end but it is doable. Hope that helps and good luck.
6/22/2019 2:13:49 PM • DCS Ovens • Answered on Jun 22, 2019
DCS oven model RGU-3GS-L will not heat up. need advise on what I can check before call a technican?
Hi Lou, sounds like you have a bad igniter. If it's not drawing enough amps it won't open the gas safety valve. Fairly simple to replace if you're confident working with electrical parts,if not I'd definitely call a repair company. Hope that helps.
4/3/2019 12:50:18 AM • DCS Ovens • Answered on Apr 03, 2019
The upper oven in my DCS WO227 is not heating properly. Two elements have been replaced, but they are still not heating.
I have attached a link to the service manual, there are relays that control the elements. https://www.manualslib.com/manual/703000/Dcs-Wo-227ss.html?page=42#manual
2/20/2019 12:33:56 AM • DCS Ovens • Answered on Feb 20, 2019
My DCS WOS-230SS top wall oven begins to heat up normally but then stops heating, the fan comes on, then begins heating up again. Got to 170 then went no higher. Could it be the element?
This is a tough question because we haven't mention the make and model number you should add that so we can help you better but normally if the top oven is not working properly it may have thermostat problem or it could also be control panel problem can you tell more information especially the make and model Sometimes you can take it out and it's not working properly and take that oven and put it in self-clean mode and it might fix problems
8/25/2018 3:43:49 PM • DCS Ovens • Answered on Aug 25, 2018
Need part for dcs oven thermostat model dcs60-24g6-2n
https://www.searspartsdirect.com/model-number/RGSC305BK/3232/0124002.html You can try this site If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_a4640839dbb7ec58
3/22/2018 12:22:22 AM • DCS Ovens • Answered on Mar 22, 2018
My DCS double oven will not turn on and the top display says lock. But both oven doors open.
is the control panel locked?i know this isn't your model because you didn't send the model number but maybe this will help you out https://www.fisherpaykel.com/vault/pdfs/pdf_usecares/590700A%20OB30DD%20quickstartA3%20USCA%20(EN)w.pdf also if you used the self clean the lock might have been damaged usually from the extra heat that's used when in self clean,the oven gets up to 1000 degrees and can damage the electronics in any stove or oven.but if you're pressing buttons and they don't seem to work the control lock most likely is on.
2/11/2018 2:51:22 AM • DCS Ovens • Answered on Feb 11, 2018
How to calibrate my DCS ovens
hi there. this is all i could find.go to this link and see if it helps you. How to calibrate DCS ovens Google Search
11/19/2017 7:15:44 PM • DCS Ovens • Answered on Nov 19, 2017
0answers
Where can i buy a replacement control display
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem- This control board is no longer available to buy new. Contact FixYourBoard.com at 512-355-1108 for more information. The photo below is from a double oven, but they repair single oven displays too. ch0509451-q0eqwqv0rnlb52n5vy4kutsd-1-0_1.jpg
7/26/2017 7:22:06 PM • DCS Ovens • Answered on Jul 26, 2017
I have DCS single wall oven model WO127 SS. Display is dim, again. Was repaired in '08 with part #211708. When I look for this part again, it says it fits WO130 with no mention of WO127. Genuine A
Good Morning Mr Villa! FixYourBoard has repairs what youre experiencing in 2-3 business days. They'd remanufacture your part, and replace your dimming display, fully test the unit.. and back their work with a 2 year warranty. http://www.fixyourboard.com
4/11/2017 2:48:18 PM • DCS Ovens • Answered on Apr 11, 2017
DCS WO-230 Stainless Steel Electric Double Oven Logo
1 questions posted
Top DCS Ovens Experts
vince
NOEL
NOEL
Are you a DCS Oven Expert? Answer questions, earn points and help others
View Most Popular
DCS Ovens
  • DCS Ovens
Most Popular Question
calibrate dcs ovens
  • Ovens
