20 Most Recent
Vantec 1 Bay NexStar NST-350UF FireWire (IEEE 1394), USB 2.0 External Drive Case Questions & Answers
Firewire/USB 2.0 both dont work..
Plug in the device( kmake sure hard drive is connected inside)
Go to computer management(right click on my computer and select manage)
on the left pane select disk management
on the right pane you'll see the drives(If a screen pops up saying about initialize disks, then proceed with that)
in the right pane if you see any unallocated volumes(big black box, full black) with the same size of your disks then you can right click on em and create a partition! The Create partition comes up and give you options to format and everything, after that completes you'll see the drive in My computer!
If you don't see the unallocated drive, then go oer the drive and account for all of em, if there an extra one without a drive letter then that could be your disk!
If you have any problems or this isn't the problem, please let me know!
regards,
babb
My Nexstar 3 drive will not load. Any Suggestions?
Let's start with the basics:
1) Is the drive getting power; is the supply correct and the connection firm? Does the drive spin-up at all?
2) Is the data cable known to be good?
3) Is the port on the computer known to be good, mechanically and electrically?
4)Does the OS support this device, or does it require additional drivers?
If it worked before, 9 times out of 10 a bad connection somewhere is at fault. Even if software or data corruption is involved, the cause is almost always an intermittent connection.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
