20 Most Recent
Daikin BRC2A71 - Simplified Individual Wired Remote Control Questions & Answers
Daikin brc2a71
This is a communication issue between the sub remote controller and the master remote controller.
This fault occurs when a remote controller that has been set to sub cannot see the master remote controller that has to be installed on the fan coil.
Please check the wiring for the remote controllers to ensure correct connections, also if there is only one remote on the unit ensure that the Main/Sub switch is set to Main.
U3 problem for vrv daikin
U3 Is a failure to carry out check operation, transmission error
This is a self diagnosis the unit does before starting to ensure both PC boards are communicating with each other. Check wiring is correct on the units, usually means one PC board has failed
Daikin fhyc140kve8
Outdoor unit will auto switch off when preset temp is reached, then switch on again auto as temp varies
Heat stops constantly
try changing pipesensor or thermostat they are most likley to go on a aircon let me know if it worked it should cause i had the same problem with mine till i changed the pipesensor and thermostat
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
