20 Most Recent Rheem RQPMA037JK R410A All-in-One Package Unit Heat Pump Questions & Answers
42 would be a 3.5 ton
I’m happy to help further over the phone at https://www.6ya.com/expert/vincent_f7b7c5f4dedd2565
Rheem RQPMA037JK... | Answered on Mar 03, 2015
that reset is for the high pressure switch. this means your compressor is getting to hot which is then increasing the pressure and tripping the switch because the fan isn't running. usually if a capacitor is bad you can give the motor a "kick start " and the blade will then start turning. use a long stick or screwdriver to spin the blade but then you will know you need a cap. that switch is protecting your compressor, don't hold it down to keep it running.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Rheem Heating &... | Answered on Oct 14, 2017
Likely a bad motor. If you have a meter and electricity confidence you need to verify that you have high and low voltage AT the motor. If both voltages present and still no motor you know it's bad. If no low voltage, possibly have a bad control board.
Rheem Heating &... | Answered on Sep 16, 2017
Rheem RQPMA037JK R410A All-in-One Package Unit Heat Pump Logo
3 questions posted
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
 Russ Hill
Russ Hill
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Rheem Heating & Cooling
Most Popular Question
btu capacity ahr42c3xh21b
  • Heating & Cooling
