20 Most Recent Honda 2001 Accord 2.3 LX Questions & Answers
96 accord ex 4cyl wont start battery new
bang, on the starter with a hamer all around the casing,the brushes wear out and no longer make contact with the comutator will useually make them move as they are sping loaded, this is a temp fix and only good 4 a cple of weeks! u can change the starter 4 abt $100 bucks or pay $150+ 2 have it done! and ur gonna get a referb bad piece with a $50 buck core charge!!!rip off. what i do is buy the brushes from th auto pts store and replace them ur self abt 6 bucks abt 1 hrs work!let me know if it worked 4 u!
11/24/2013 1:00:35 AM • Honda Heating &... • Answered on Nov 24, 2013
WE HAVE A FEDDERS AZ7A09W2A Through the Wall Room Air Conditioner. IT WILL NOT TURN OFF. PULLING THE POWER CORD IS THE ONLY WAY. DOES ANYONE KNOW THE CAUSE AND OR REPLACEMENT PART?
Question edited for clarity, full 'make model (what it is)'. Email address removed. You don't need the site's 12 million annual viewers emailing you to say they can fix it for a thousand bucks! Finally, Please don't type in all CAPS, it is considered SHOUTING and is harder to read. Repair Clinic has some good ideas, but your model is discontinued
Fedders Air conditioner won't turn off
Repair Clinic https://www.repairclinic.com > RepairHelp > Fedders-Ai... Here are the most common reasons your Fedders AC compressor won't turn off - and the parts & instructions to fix the problem yourself.
Why Your Air Conditioner Isn't Shutting Off, and How to Fix It
Williams Comfort Air https://williamscomfortair.com > ac-wont-shut-off When your air conditioner won't shut off, it's natural to worry about wasting electrical power as temperatures become too cool for comfort. ..
4/24/2024 1:44:56 AM • Heating &... • Answered Yesterday
2answers
I have a Bonair evap aircon model VSL75 with the comfort controller and I want to reduce the water dumping cycle down. I have tried the manual but that sequence didn't work.
Here are the steps you might want to follow: Setting the Draining Cycle Times (Dump Interval): This setting controls how often the unit dumps the water. You can adjust this setting to reduce the frequency of water dumping. Setting the Drain off Delay Time (Dump Delay): This setting controls the delay time before the unit starts to dump the water after it has been turned off. If adjusting these settings doesn't work, there could be other issues with your unit. For example, a continuous water dumping problem could be due to a faulty dump valve or a problem with the float valve.
4/21/2024 11:19:53 PM • Heating &... • Answered 3 days ago
What is E3 in frego split ac
Frego split ac error code h3 what is problem
4/16/2024 4:25:39 AM • Heating &... • Answered on Apr 16, 2024
2answers
What does E2 code mean on electric infrared heater
Model 2320cpb. E2 code
4/13/2024 11:00:34 AM • Heating &... • Answered on Apr 13, 2024
HP error code in bluestar split ac
Blue star inverter Ac HP error shown on display
4/10/2024 7:14:47 AM • Heating &... • Answered on Apr 10, 2024
2answers
Hello How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM • Heating &... • Answered on Apr 09, 2024
My azure split ac see the error code df sir pls give me solution for df error
Azure 1.5 ton splits ac old model e2 error
4/9/2024 12:44:23 AM • Heating &... • Answered on Apr 09, 2024
My Goldair gas heater ignites but the centre burner does not glow or come on. What could be the problem?
Blocked jets clogged with dust or dirt, blocked injector need a clean / service
4/8/2024 8:36:41 PM • Heating &... • Answered on Apr 08, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps: Unplug the heater from the power source. Locate the Manual Reset Button on the heater. It's usually a small button or switch. Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button. After resetting, plug the heater back in and check if it functions properly. Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM • Heating &... • Answered on Apr 07, 2024
Kolin window type aircon is turned on but has no display. What can this mean and how to fix?
https://www.fix.com/repair/appliance/air-conditioner/does-not-turn-on/
4/2/2024 11:36:49 AM • Heating &... • Answered on Apr 02, 2024
5answers
How to solve ul error code in voltas package ac
Sir my package Ac is .UL error code sir
4/1/2024 10:37:13 AM • Heating &... • Answered on Apr 01, 2024
I need to replace my front panel on a Newlec NLSH 24AN storage heater. Probably 2nd hand as heater now discontinued . Anyone know of any sites , links etc to look for one ? Thanks
Parts suppliers in the link. Ot if you take the old one off, a metal fabrication workshop could make you a new one. https://www.google.com/search?q=Newlec+NLSH+24AN+storage+heater+parts They still sell them and they all look the same. https://www.hwelectric.co.uk/newlec.php ..
3/29/2024 6:42:46 PM • Heating &... • Answered on Mar 29, 2024
Can this unit be installed thru a wall with the sleeve/ box that comes with it? CW-XCI20AU
Obviously window and wall a/c units are not tradable, in spite of the fact that I don't have the subtleties of the distinction. Alter Window units are intended to exploit the way that a window is a flimsy segment; vents outwardly of the a/c case can be near within part of the a/c unit, yet be outside (where they must be). This might permit the window units to be less expensive. Interestingly, a wall can be 6" thick or more; wall units should have all vents near the rear of the unit. BTW I generally felt that the vents in the side of a window unit were for admission of air at encompassing temperature to then be coordinated through the condenser curl at the back plane of the unit to be depleted out the back (presently more sweltering than surrounding), however as a matter of fact a portion of the side vent region may likewise be utilized for ousting air which cools engines. It may be the case that in a window unit the venting on one side is committed to admission of air for the condenser loop and the venting on the opposite side is for exhaust. This would forestall the hot exhaust air being pulled in the admission for the condenser cooling air. Window ACs versus Through-the-Wall ACs It's not difficult to think about window and through wall ACs, since they're comparative in cooling limit and size, yet through-the-wall units will generally be somewhat more productive in light of the fact that they make an impermeable seal in the room. The significant contrasts between these ACs include establishment and venting. Window ACs fit through a window and don't need long-lasting establishment, while through wall ACs are really incorporated into the wall - making them well known in rooms without windows or for individuals who like to let their windows be. Wall forced air systems normally just vent warm air through the rear of the unit, while window ACs vent from the sides and back. Hence, window and through wall models are not exchangeable (regardless of whether they're a similar size). Generally speaking, in the event that a window unit vents out its side, the wall will obstruct the vents and cause overheating. Select window AC models can be introduced through a wall, however provided that they have a slide-out case wall sleeve. Peruse more on wall sleeves.
3/25/2024 3:48:35 AM • Heating &... • Answered on Mar 25, 2024
Voltas 03 error showing in cassette ac
Maybe this video will help: https://www.youtube.com/watch?v=xOZGx6--B2A
3/23/2024 11:32:43 PM • Heating &... • Answered on Mar 23, 2024
DAYTEK ASW-H12A4/SQC SPLIT UNIT AIRCON. E4 ERROR
Hi I'm getting e4 on my aircon daytek
3/22/2024 2:47:50 PM • Heating &... • Answered on Mar 22, 2024
Operation light always blink and ac start on its own
Impossible to answer without 'make model (what is is)'. That should be the first 3 words in every question.
Troubleshooting ' Air Conditioning and Refrigeration
Daikin https://www.daikin.com > products > ac > services > trou... If the operation lamp still flashes, disconnect the power plug from the outlet or turn the breaker off and contact the place of purchase. Are there any objects ...
Air Conditioner Light Blinking Problem Solving Techniques ...
absolutesolutions.com.sg https://www.absolutesolutions.com.sg > news > why-my... Nonetheless, a blinking light is mostly an indicator that your unit needs to be serviced if you expect it to not only service you back but to do so efficiently.
Have model ras-17ekv-ul green operation light and orange
JustAnswer https://www.justanswer.com > HVAC Questions Jun 25, 2020 - You may have had a power failure. Try resetting the breaker. Flashing green indicates power loss. Flashing orange for outdoor circuit board ... 1 answer ยท Top answer: It shouldn't as long as the unit is off when you kill power. ..
3/22/2024 2:54:48 AM • Heating &... • Answered on Mar 22, 2024
1999 Nissan Sentra XE 1.6l V4 will blow heat for a few moments after driving for long periods of time. Otherwise blows a cold temp.
Question edited for clarity. Stuck blend door actuators, stuck thermostat, or this, airlocks. https://www.fixya.com/support/r29872074-vehicle_cooling_system_no_heat ..
3/20/2024 5:13:44 PM • Heating &... • Answered on Mar 20, 2024
Honda 2001 Accord 2.3 LX Logo
2 questions posted
Top Honda Heating & Cooling Experts
Paul Carew
john h
Are you a Honda Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Heating & Cooling
Most Popular Question
car will not start dash lights
  • Heating & Cooling
