20 Most Recent Kirby Brushroll With Magnet G5-DE Stiff Bristles Questions & Answers
My Ultimate G will only switch on if the handle is at an angle, if upright it shuts off.
I thought they all switch off when the handle is at rest in the upright position, for safety.
12/24/2023 11:00:50 AM • Kirby Vacuums • Answered on Dec 24, 2023
2answers
How do I change the belt on a Kirby Vacuette?
heres a video
11/25/2023 6:57:01 PM • Kirby Vacuums • Answered on Nov 25, 2023
How do I use my new Kirby shampooed on my cat tree?
6/22/2023 11:36:37 AM • Kirby Vacuums • Answered on Jun 22, 2023
How to change brush on kirby heritage 2 rug renovator
6/22/2023 11:30:37 AM • Kirby Vacuums • Answered on Jun 22, 2023
How to stop the shaft from spinning on a kirby g4 when trying to remove the spindle
If you're experiencing difficulty in removing the spindle on a Kirby G4 vacuum cleaner because the fan is spinning on the shaft, there are a few steps you can try to address this issue: 1. Unplug the vacuum cleaner: Ensure that the vacuum cleaner is unplugged from the power source to avoid any accidental injuries. 2. Secure the fan: Take a closer look at the fan assembly and identify if there are any parts that can be held or secured to prevent it from spinning. You may need to use tools like pliers or a wrench to hold the fan in place while you work on removing the spindle. Be cautious not to damage the fan or other components. 3. Determine the direction: Confirm the direction in which the spindle is threaded. Most Kirby vacuums have reverse-threaded spindles, which means you will need to turn it counterclockwise to loosen it. 4. Apply force to the spindle: Once the fan is secured, try applying counterforce to the spindle by turning it counterclockwise. You may need to use a wrench or pliers for better grip and leverage. Apply steady and controlled force, but avoid using excessive force that could potentially damage the components. 5. Penetrating oil: If the spindle is stubborn and difficult to loosen, you can try applying a small amount of penetrating oil, such as WD-40 or similar lubricants, to the junction between the spindle and the shaft. Allow it to sit for a few minutes to help loosen any potential corrosion or debris that might be causing the resistance. 6. Repeat the process: If the spindle still doesn't budge, repeat the steps above, ensuring that the fan is securely held in place and you're applying the correct force and direction to the spindle. If you continue to experience difficulty or are unsure about proceeding, it might be best to consult a professional or reach out to the Kirby customer support for further assistance. They can provide more specific guidance tailored to your vacuum model.
6/20/2023 3:48:42 PM • Kirby Vacuums • Answered on Jun 20, 2023
I replaced the belt on my 1978 Kirby 3CB shampooer and it keeps coming off the spindle of the vacuum? The shampooer attachment is not that old and hasn't been used much. Everything is clean too.
From my memory of a Kirby I had in the early 80s the belt has a twist in it. It has do go on the right way. One way pulls it on, and the other throws it off due to the rotation of the motor shaft. https://www.google.com/search?q=kirby+3cb+replace+belt ..
5/29/2022 4:44:52 PM • Kirby Vacuums • Answered on May 29, 2022
The handle tilt latch on my Kirby Sentiera is jammed on the bag side and won't move
Question edited from 'Senteria' to 'Sentria', and added full 'make model (what it is)'. Question moved from Computers and Internet to Kirby Vacuum. Details on disassembly in the link. https://www.google.com/search?q=Kirby+Sentria%2C+handle+tilt+latch+jammed ..
12/19/2021 7:42:25 PM • Kirby Vacuums • Answered on Dec 19, 2021
Kirby made a loud clunk then got real loud
sounds like a motor bearing might be bad
10/11/2021 10:19:42 PM • Kirby Vacuums • Answered on Oct 11, 2021
Sentria goes in reverse when pushed. Goes forward when pulled. What is the fix or adjustment?
Contact Kirby direct
Sentria - The Kirby Company - Kirby Vacuum
https://www.kirby.com > earlier-kirby-models > sentria
The Sentria Model includes softer lines and gentler curves on its design, giving it a sleek and soft look. The handle was redesigned on this model to provide ...
5/31/2021 11:00:39 PM • Kirby Vacuums • Answered on May 31, 2021
I have a Kirby Sentria. The post that the belt goes on gets very hot quickly. The roller brush is clean, the new belt is on correctly and the bag is almost empty.
try running motor without belt if still gets hot motor overheating if doesnt get hot make sure belt not slipping
12/14/2020 6:16:44 AM • Kirby Vacuums • Answered on Dec 14, 2020
My kirby on and off switch sticks and will not turn on how do I fix this?
The switch has become defective and will have to be replaced.
12/7/2020 3:07:43 PM • Kirby Vacuums • Answered on Dec 07, 2020
My Kirby heritage 2 won't start. How do I check the foot swtich?
There should be a definite audible click when you press down on the switch. Most switches also latch so that there is a little play in the foot switch when it is on. Possible problems included - blown fuse in the plug, damaged cord, failed starter capacitor. It may be an idea to take it to a local vacuum repair store and get an estimate for repair.
8/18/2019 3:03:13 PM • Kirby Vacuums • Answered on Aug 18, 2019
Changing the on/off switch on kirby legend
Remove rear housing /3 screws and one under cover. Remove wires with paperclip install screw clip and reinstall. Also one screw under rear wheels , loosen don't remove as it helps hold lower section on the switch.
6/5/2019 2:44:28 PM • Kirby Vacuums • Answered on Jun 05, 2019
I have a Kirby G6 and carpet shampooer won’t foam or produce even foam / water - I have tried : Soap sue plug is in place Sponger filter in place neither of these parts are clogged . Attached correctly has anyone else had this problem please ?
If you are using the correct shampoo then the tank my need to be replaced. They will clog if tank wasn't cleaned after last used. Check that the dial is open and both filters are in place , add water and shampoo and test without the hose connected . If you still have no suds coming out then just order a new tank.
5/14/2019 1:53:36 PM • Kirby Vacuums • Answered on May 14, 2019
Kirby Heritage 84 will not turn on with hose attachment. Why did this suddenly start happenings?
The switch bar is bent , and needs to be replaced. You can try to re-bend it but this takes some skill. Take the bar out and lay it flat and you will see the where to straighten .
5/14/2019 1:48:56 PM • Kirby Vacuums • Answered on May 14, 2019
How do you remove the end caps of a Kirby sentria vacuum agitator ?
You can pry them off , just make sure they go back on the correct end.
5/14/2019 1:46:20 PM • Kirby Vacuums • Answered on May 14, 2019
How do I reattach my belt on my Kirby vacuum cleaner?
Watch this YouTube video:
https://m.youtube.com/watch?v=rmpbFD_V2MU
4/23/2019 11:32:19 PM • Kirby Vacuums • Answered on Apr 23, 2019
Kirby Brushroll With Magnet G5-DE Stiff Bristles Logo
1 questions posted
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kirby Vacuums
  • Kirby Vacuums
Most Popular Question
ultimate g will only switch handle
  • Vacuums
