20 Most Recent Craftsman Shop Vac 8 Gallon Replacement Filter Questions & Answers
If the check ball is stuck closing airway, the strike the unit on top when its off, you may hear the ball drop and there try again. Otherwise, if that's not it, most like the fan portion inside to create air movement has separated from shaft of motor assembly. You may try top open top and reconnect, but if you not sure don't try this. Take a look at product info for possible replacement or back to store for advice.
Craftsman Shop... | Answered on Dec 13, 2014
Maybe it over heated or the hose was jammed. Unplug it for a few minutes, check the hose for any stuck debris, then plug it back in. Shop vacs also come with a filter. If the filter is too dirty, it might have shut off as a safety precaution to not cause a fire. Follow directions to clean the filter. Hope this helped. Dee
Craftsman Shop... | Answered on Oct 14, 2014
I don't know exactly but if it has one it will usually be found in intimate contact with the motor.
Some vacs were fitted with a bimetal breaker which is also sited close to the motor, but sometimes there is so much dust around once they open they fail to make a good contact again when the cool and close.
Older vacs weren't fitted with any safety devices.
Craftsman... | Answered on Nov 11, 2017
Yes, you need to take it apart. Maybe ask a friend who knows Mechanics or Electrical.
Craftsman... | Answered on Sep 01, 2017
Most wet dry vacs have a ball float that blocks the vacuum when it is full of liquid. Yours sounds as if it is full or the ball has gotten stuck in the up, or blocking position.
Craftsman... | Answered on Jul 04, 2017
Absolutely yes. If not, the filter will be saturated with water and ruined.
Craftsman... | Answered on Nov 02, 2016
First check if the bag is full. Then check if hose is clogged or attachment is clogged.
Craftsman... | Answered on Mar 06, 2015
Either the bulb blown or not wired right when installed. should have one red wire, one black wire and a ground wire, green or copper.
Craftsman... | Answered on May 27, 2014
Craftsman Shop Vac 8 Gallon Replacement Filter Logo
2 questions posted
Top Craftsman Vacuums Experts
Vernon Taylor
ray gallant
SANE AGAIN
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Vacuums
  • Craftsman Vacuums
Most Popular Question
shop vac jsut hums
  • Vacuums
