20 Most Recent Rainbow Aquamate Carpet Shampooer Questions & Answers
2answers
Rainbow E-Series Vacuum cleaner. Where can I find a Rainbow repair man near me zip code 95642.
Question edited for clarity.
Contact Us - Rainbow® Cleaning System
rainbowsystem.com https://rainbowsystem.com > Support Contact Rexair's Customer Service Department if you have questions about any Rainbow product, including questions about authorized repair and maintenance. Or https://www.google.ca/search?q=vacuum+cleaner+repair+near+me ..
1/8/2024 10:27:31 PM • Rainbow Vacuums • Answered on Jan 08, 2024
I have Rainbow vacuum R-1650. Why does water I am dumping out look foamy?
Because you are pulling shampoo out of the carpet from a previous shampooing. Also the air whips around inside the waste bucket. Incidentally.... https://www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?958 ..
12/20/2023 12:39:21 AM • Rainbow Vacuums • Answered on Dec 20, 2023
Rainbow SRX motor spinning slow
Sounds like an unwanted ingress of water into the motor assembly. Not a lot can be done without stripping the machine down and taking a look at any damage.
8/16/2023 6:51:51 AM • Rainbow Vacuums • Answered on Aug 16, 2023
Rainbow vacuum E2 smoking hose
If your Rainbow vacuum E2 is experiencing smoking and a red blinking light, it indicates a potential issue with the electrical system or a blockage in the airflow. Here are a few steps you can take to troubleshoot and address the problem:
  1. Safety first: Turn off and unplug the vacuum immediately to prevent any further damage or potential safety hazards.
  2. Inspect the hose: Carefully examine the hose for any visible signs of damage, such as cracks or holes. Ensure that the hose is securely connected to both the vacuum unit and the wand. If you notice any damage, it may be necessary to replace the hose.
  3. Check for blockages: Remove the hose and wand assembly from the vacuum and inspect them for any blockages or obstructions. Pay particular attention to the areas where the smoking occurred. Clear any debris or blockages that you find.
  4. Clean or replace the filters: A clogged or dirty filter can restrict airflow and cause the vacuum to overheat. Remove and clean the filters according to the manufacturer's instructions. If the filters are worn out or damaged, it may be necessary to replace them.
  5. Electrical system check: The red blinking light indicates a potential electrical issue. Examine the electrical connections and cords for any signs of damage or loose connections. If you notice any issues, it is advisable to have a professional technician inspect and repair the electrical components.
  6. Seek professional assistance: If the smoking and red blinking light persist after performing the above steps, it is recommended to contact the manufacturer's customer support or a professional vacuum repair service. They can provide further guidance and assistance in diagnosing and resolving the issue.
5/27/2023 3:48:12 AM • Rainbow Vacuums • Answered on May 27, 2023
2answers
Rainbow vacuum red light comes on and it won't work
Need more info. By not working do you mean the motor is not running, the beater bar is not turning or is the red light in the rainbow unit itself.
2/5/2023 8:39:43 PM • Rainbow Vacuums • Answered on Feb 05, 2023
Rainbow Vacuum AquaMate (Carpet Cleaning System). My Aquamate keeps leaking.
Question edited for clarity. If you can get the trigger unit apart, you will almost certainly find a spring that pushes the trigger back and an O-Ring that is sticking. Both parts can be found in Home Depot or similar. Clean and reassemble with some Vaseline for lubrication. Parts are available https://www.google.com/search?q=aquamate+type+12+parts Leaks https://www.google.com/search?q=aquamate+type+12+leaks ....
12/23/2022 12:58:10 AM • Rainbow Vacuums • Answered on Dec 23, 2022
Rainbow SRX upright release button not self rising anymore
try to lubricate it
8/28/2022 5:30:06 AM • Rainbow Vacuums • Answered on Aug 28, 2022
Why does water sprays out from faucet when attaching shampooer connection
It needs to have a rubber gasket like on your washer hose on it. Should solve problem
9/28/2020 2:44:09 PM • Rainbow Vacuums • Answered on Sep 28, 2020
I have a rainbow black e2 series. My power nozzle won't stay running but if I connect to the gas pump handle to the power nozzle l it works great. So I replaced both wand pieces and I'm still having the same issue. Kinda confused
It may be the pivot arm. That is the neck on the power head that the wands connect into. The way to check that is by putting the handle directly into the neck and with it running, move handle back and forth forward and backwards to see if it has a short in the hose part of neck
9/28/2020 2:38:19 PM • Rainbow Vacuums • Answered on Sep 28, 2020
Rainbow controler
Yes it will work.
9/28/2020 2:34:43 PM • Rainbow Vacuums • Answered on Sep 28, 2020
I have a Rainbow Vacuum, the red light has come on. Also the brush on the power head spins and stops, spins and stops....???
This is because your beater bar bearings or motor is going out. Check both. You can check them by rolling the stem of the motor with you finger to see if motor bearing is damaged. It should roll very smoothly.
9/28/2020 2:33:43 PM • Rainbow Vacuums • Answered on Sep 28, 2020
Rainbow e series vacuum with power head PN-12 that does not come on. Switch and motor are good.
Check the electric cord on the power head.
11/22/2019 4:47:05 PM • Rainbow Vacuums • Answered on Nov 22, 2019
Rainbow Aquamate Carpet Shampooer Logo
6 questions posted
Top Rainbow Vacuums Experts
Mike Cairns
Mike Cairns
Thomas Perkins
Thomas Perkins
Kardoc
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Rainbow Vacuums
  • Rainbow Vacuums
Most Popular Question
rainbow srx motor spinning slow
  • Vacuums
