20 Most Recent Singer 8763 Curvy Computerized Sewing Machine Questions & Answers
could be a computer problem, if the problem keep happening the machine needs to be checked
Singer 8763... | Answered on Feb 17, 2016
there are several things that may cause this situation.
the needle may not be seated all the way up where it is supposed to be.
here is a site that may give you more insight.
How can fix the needle hitting the bobbin case on my sewing machine
Singer 8763... | Answered on Mar 05, 2015
sounds like a blunt needle,or tension at wrong setting.replace needle first.adrian,,,,
Singer 8763... | Answered on Feb 12, 2015
Lubricate the moving part oil ways with Singer oil.
3in1 will damage the bearings!
Singer Sewing... | Answered 8 minutes ago
look in you manual under messages or helpful message it should tell you what the problem is then you can correct it
Singer Sewing... | Answered on Oct 18, 2020
Hi I have been trying to get a manual for the Singer magic9 no 8209 but can't seem to find one anywhere I wonder if you would be able to help thanks Jan
Singer Sewing... | Answered on Aug 29, 2020
Steps:
1) Reset the stitch and width settings back to the settings before the malfunction began.
2) If it's computerized, try 'rebooting' by turning the machine on and then pulling the plug from the mains.
If the 2 suggestions don't work, you may have a broken gear.
The best thing you can do is call customer rep of Singer and talk to them about your concern.
Here's something too:
https://help.brother-usa.com/app/answers/detail/a_id/123359/~/machine-is-stuck-on-reverse
Singer Sewing... | Answered on Aug 20, 2020
Singer has many of the manuals for their machines here: https://www.singer.com/support . The current link to the model 50 manual is https://res.cloudinary.com/singer-sewing/image/upload/fl_attachment/Singer-Website-Library/outdated_product/SINGER_50_Sewing_Machine.pdf . See page 13 for the oiling directions. Ismacs.net has information on dating Singer sewing machines here: http://ismacs.net/singer_sewing_machine_company/serial-numbers/singer-sewing-machine-serial-number-database.html . However, your numbers don't match the Singer serial numbers that I know. Most serial numbers either have no letters or one - two letters at the beginning of the number. There was a period when Singer used both a Registration and a Factory number to in the serial numbers. However, that ended before 1900 with the 12K batch.
I hope this helps.
(Note: the manual to which I provided a link indicates the model 50D with a copyright date of 1962. Singer manuals are the same for all letter suffixes.)
Singer Sewing... | Answered on Aug 19, 2020
Singer 8763 Curvy Computerized Sewing Machine Logo
9 questions posted
Top Singer Sewing Machines Experts
Chris Wetmore
dannydoesita
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
am ttying wind bobbin when stsrt machine
  • Sewing Machines
